-   -   got some H4's, but... (http://forums.pelicanparts.com/porsche-911-technical-forum/54214-got-some-h4s-but.html)
broseed 12-12-2001 02:00 PM
Hi everyone!
I recently purchased the H4 upgrade for my '81SC here at Pelican - but two of the retaining screws for one of the headlights are stripped (well, the threads are ok I think, but my phillips can't fit in to the grooves on the head - the metal is really soft - so now there is a big circular hole in the screw head) - i'm wondering if any of you have any tips on getting these screws out???
Thanks,
Superman 12-12-2001 02:08 PM
American ingenuity. Sadly, there are jobs that a good hammer still won't perform. I'd consider needle nosed pliers or a reverse-threaded drill bit.
911pcars 12-12-2001 02:17 PM
Superman's choice of a left-handed drill bit is my choice as well.
Lacking this, use a large-enough drill bit to drill through to remove the Phillips head. Once the headlight assembly is off, use needle-nose pliers to remove the remaining portion of the screw.
Sherwood Lee
http://members.rennlist.org/911pcars
