-   -   I need help with triple-choke Webers! (http://forums.pelicanparts.com/porsche-911-technical-forum/542334-i-need-help-triple-choke-webers.html)
a310man 05-14-2010 07:45 AM
Hi 911 forum
I am new to the forum and, although not a 911 owner, have a question about triple-choke Webers.
One of my cars is an Alpine-Renault A310 V6 (website Alpine-Renault A310). I have rebuilt the car into a replica of the A310 that competed at Le Mans in 1977.
At present, I am running a Dutch Youngtimer Challenge engine, which means the capacity must remain standard at 2664cc. However, it has modified, pocketted Mahle pistons and race cams. To feed the go-juice, it is currently fitted with a triple Weber 42DCNF setup and runs well on this arrangement.
However, as I continue development, I have bought a pair of triple-choke Webers with 40IT 100 stamped one one of them. They came as a second-hand pair from the same car (911), plus repair kits with gaskets, 'O' rings, copper rings and float valves. I also have a carb manual, but the tops of the carbs are different from the carbs shown in the manual and different from most other triple-chokes I have seen in that there is only one fuel inlet on the carb top. The floats are suspended from the carb top, rather than 'floating' in the float chambers. I hope I have managed to add pics. Where can I buy float valves that fit in the underside of the carb top? And what car where these carbs originally intended for? They were sold as from a 911, but which one I do not know. HELP!!http://forums.pelicanparts.com/uploa...1273848196.jpg
a310man 05-14-2010 08:44 AM
Triple-choke Webers
http://forums.pelicanparts.com/uploa...1273851688.jpg
Here is the engine with its 3 x Weber 42DCNF carbs. It is good for just over 200hp.
http://forums.pelicanparts.com/uploa...1273851821.jpg
And here is the car itself.
Quickstep192 05-14-2010 08:59 AM
Try PMO at PMO High Performance Porsche 911 Carburetors & EFI & MFI Fuel Injection Kits
I find it best to fax them a letter with what you need. Include your phone number so they can reach you.
Quickstep192 05-14-2010 09:02 AM
Oh, one more thing......
If they're like the 40IDAs I have, you'll also need shims (washers) to adjust the float level when you replace the valves.
Steve@Rennsport 05-14-2010 09:16 AM
Love your A310,...:)
Wow,..in all my years, I've never seen any Weber triple IDA/IDT's in that configuration. Might those possibly be the Lamborghini version of that carburetor? Triple Webers were used on the Miuria and Ferrari 512 BB, as I recall.
Those floats adjust like a PMO or any other normal carb; by bending the tang on the floats to suit. The specs are in the Weber manuals or the Haynes version. Without seeing the float needles, I cannot tell you if they are standard ones or not.
a310man 05-14-2010 11:38 AM
Triple-choke Webers
Hi again chaps
Thanks for the information. I had only seen a couple of pics of the carbs when I bought them and it wasn't until I was ready to rebuild them that I noticed the odd arrangement for the fuel inlets and the float locations. There are no float needle valves fitted - just the holders. Those are the bits I need. Here is a pic of one carb showing the lack of float valves and the float fixing.
http://forums.pelicanparts.com/uploa...1273862319.jpg
Oh - the engine is rear-mounted like the Porsche 911. Hung out in the breeze way behind the rear axle line. Handles somewhat sweeter than a similar vintage 911 though and it is nice owning three of these very different French coupes.
a310man 05-15-2010 07:51 AM
Triple Webers
Thanks to Quickstep192 and Steve@Rennsport for the replies. I have contacted a German link from the PMO website and will update you as soon as I have discovered more about these carbs.
What a superb forum!
