Obsessed
Front VIN Plate restoration
Hi all, so far the only VIN indication I can readily see on my car ('75 Targa) is the plate by the fuel tank. The bonnet area has been cleaned up and sprayed by the P.O. during a partial restoration, so I can juuuust barely read the VIN number on that little spot.
Is there a way to strip back the paint on it and expose the VIN better or will I be potentially erasing whats left of the stamp? I'm only really concerned with titling and registering her shortly and don't want the DMV to give me any hassle. She's not ready for the standard issue "I'm the happiest dude alive because I finally got my dream car" thread yet (but she's not too far off), so please don't shoot me for a lack of pics. Thanks, Travis
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
If I needed to do this I would tape around the area and use some hardware store chemical paint remover on the vin area. I don,t think you want to sand or grind it, just remove the layers of paint.The numbers should be clear and undamaged after you remove the paint
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Are talking about the stamped tub near the fuel tank? Is there no VIN plate on the A pillar by the door hinge or an aluminum plate on the right fender area inside the trunk? A picture would help. If you have the aluminum stamped and riveted plate and it is painted over, then yes, a chemical paint stripper would be best.
Did the previous owner not give you a confirmed VIN as part of the sale?
Tony G 2000 Boxster S |
Obsessed
Yep, I'm speaking of the stamped spot just to the left above the fuel tank.
I couldn't find anything on the A-pillar, will look again for something near the fender. I read after about something under the dash to look for (that may or may not match the VIN) The spot above the fuel tank does match the title, all confirmed at the time of sale. My car has been at least re-painted twice and was undergoing a fairly extensive restoration, body and paint-work complete when the PO lost interest in it and it sat for a couple years. She's on her 3rd color change so I wasn't shocked to find the traces of origin rather erased over the years. I just wanted to make sure that paint stripper wouldn't harm the stamped numbers too. I'll try to take a picture of it later, not sure how much or how well it will show up.
check out this thread. Has pictures of what to look for and where. Also what a 'suspect' VIN plate looks like.
This VIN Does not read right
The '75 cars did not have the A pillar VIN. ROW cars didn't either.
They just had the stamped/engraved number in the trunk by the fuel tank. Originally it had black paint on it. The riveted aluminum plate is also in the trunk on the inside of the right fender a bit forward and above the stamped number. Go to TonytheTarga's post above this one, click on the "VIN" link and go to Ossiblue's post #20 for a pic of where they are. I once had a car that the PO had sprayed the thick speckled epoxy trunkliner stuff in the trunk. I used heavy tape around the VIN stamp and used a wire brush to get it off, then dug the paint out of the recessed numbers with a dental pick. Then sprayed it satin black. Looked fine, did not damage the VIN. I couldn't at the time get all the epoxy stuff out of the trunk. Last edited by tcar; 05-14-2010 at 08:53 AM.. |
Formerly known as Syzygy
As I understand, ROW cars have no A-pillar VIN plate. If yours is one of those, then no plate there.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Obsessed
I feel I read concern in some posts above, I appreciate it but for the record I feel like there is almost zero chance there's a thing fishy about my car. I purchased it through a well regarded Pelican member and the stamped spot matches the title in hand and reads properly for the correct year, body style, etc. There's nothing ground off on the engine (it's been transplanted to a 3.0 which does have it's 930 numbers stamped on it
) and I did find the build number on the dash today while cleaning. I believe that through the years the tag on the fender got damaged or removed by one of the updates/resprays. She's just not a pampered garage queen in original condition but I hope to give her a fine home for a long long time ![]() At this point I'm merely trying to make my local DMV visit as quick and painless as possible.
tape around the letters / numbers and use some lacquer thinner with a tooth brush to clean out some of the paint. I'd tape right up to the border of the letters.
Doug
1971 RSR - interpretation |
Obsessed
ahh, well thank you and I stand corrected.Yep, I do have title and bill of sale in hand, but found from past experience they require the car also present if it's coming from out of state. Gotta love Aly-Bamy
