Are RS door handles sturdy?
Out host and others sell these plastic repro RS door handles. The originals were also plastic I believe. Anyone know if they will survive a panicked passenger hanging on for dear life in a high speed corner?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
I would rather be driving
No, they are not sturdy. In fact, they did not survive shutting of my fiberglass doors.
I made a simple strap with a length of leather that fits across the two holes after mine broke. Someone makes a metal replacement? TRE?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Wevo makes metal ones, I've had good experiences with their products before.
Welcome to Windrush Evolutions - WEVO - Porsche Products
'87 911 Coupe '95 911 Coupe '04 911 GT3 '98 Jeep Wrangler |
Exactly what I needed. Thanks to both of you. Jim
GT racing sells aluminum handles which are drilled out and look pretty cool. You could also PC them if you don't like the metal look. There are also different versions of the rs handles where the handle does not have a hinge and is covered in padded black vinyl.
72 911 Although it is done at the moment, it will never be finished. |
I've definitely broken a few of those plastic handles.
Normally just not "reefing" on them will allow them to survive. But I've always got a couple of "spares" just in case. I think the WEVO replacements look pretty nice.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Very helpful. Thanks, Jim
they have about 50 cycles then they break. I put a nylon web loop under the front part of my leather strap and use that to close the door.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
