Alan.UK's Avatar
Can you buy this part ? and advice
Hi all,
To cut a long story short I am interested in buying an 911 x race car which is for sale. It's 72 2.4 which is mechanically very sound. The gear box has been completely gone through, engine has had much work, webers, 7R case, sssi exchangers, extra oil cooling, up rated oil pump.. so on. Brakes and suspension have also been produced for the track so it’s stiff as hell. There’s no interior bar, two buckets, harnesses and a roll cage.
So basically I'm looking for advice as I don't know what to do?? It will need a lot of work as the mech’s are great but the body is messy and will take a lot of adapting.
Also the current owner had an accident when the bonnet clips were left undone and when driving the bonnet lifted up and as a consequence it has bent all the scuttle in. There is now a gap approx half an inch under the windscreen where the scuttle has been bent down. The bonnet is also ruined
Does anyone know if you can buy this panel, and how hard it is to replace and line up.
Thanks in advance
Alan
Old 12-14-2001, 06:43 AM
Hi Alan
Is the car a 1972 911T red and yellow with a ducktail and RS front
if it is iknow every thing about the car
Old 12-14-2001, 08:53 AM
