-   -   Help needed to re-establish timing (http://forums.pelicanparts.com/porsche-911-technical-forum/543131-help-needed-re-establish-timing.html)
dsmyth 05-18-2010 04:58 PM
In error ,I turned my engine over by hand after I removed my distributer on my 85. I have 3 timing marks on my pulley with square cut grooves spaced at 120 degrees. My engine is out of the car after a reseal. I think I need to find tdc for cyl #1 and put the distributer back with the rotor pointing to the cut mark. How should I best do that. My valve covers are back on? Thanks for any suggestions . Doug
James Brown 05-18-2010 05:29 PM
Easy, if the engine is out if the car. Pull all the plugs out except #1 plug and hand turn it over untill it gets hard to turn, that is close to TDC so go slow and stop at TDC. Insert dissy as you stated, replace plugs.
Eagledriver 05-19-2010 05:45 PM
Very clever idea.
James Brown 05-19-2010 09:43 PM
All in a days work for a flight engineer!!
