Engine Displacement Question
I want to find out what is the largest diameter cylinder and largest stroke crank
I can put into a 3.0 SC case. |
I want to start with a 3.0 case since most members think this is a very strong case.
Ping Charles Navarro at LN Engineering to check - cnavarro on this forum. IIRC it is 102mm at the bleeding edge, but 100mm is the ideal max.
As far as the crank goes, I think you can use a 993 or GT3 crank and stroke it to 76mm.
| All times are GMT -8. The time now is 01:41 PM. |
