defcon65's Avatar
Engine as jack point?
Wayne's book says go ahead and place the jack under the engine where the case halves come together. Porsche manual says NEIN! Who's right? Any opinions? What do you do?
Joe
Old 04-24-2006, 11:19 AM
Lots of threads on this topic. Here's one.
Lifting Points
I used to use the engine as a jack point but I think that's just wrong. It's not difficult to find another jack point, so in my opinion, it's simply not worth even a minimal risk that the engine would be harmed.
That said, I'd balance an engine and tranny on a jack pad like Pelican offers, but the added weight of the car is a different matter and seems to place a great deal of weight on opposite ends of the crankshaft.
"Rust never sleeps"
Old 04-24-2006, 11:37 AM
Hi Joe,
This an age-old question. Every shop I have seen over the years (yes, I've only gone to good shops, no hacks) has lifted 911's rear end from the engine, either for a quick inspection, or to put on jackstands. Moreover, everyone I've known who works on their 911 has done so for decades w/o harm. And I, myself, have done so for my 911s for the almost 6 and 2 years I've owned my two. I do 99% of the maintenance/mods so this is not an infrequent occurance. Do a search, and I think you'll find the same. Hope this helps you.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 04-24-2006, 11:42 AM
loot87's Avatar
It depends on the car. Since this is the 911 forum, I'm assuming you have an 80s or prior 911. A jack pad is a great option for that and that's how I did my 83. But with a 964, I don't see an alternative to the engine as the receptacles for the jack pad are gone. I suppose I could rig up a cross bar so it would be like the rear part of a shop lift. But I just use the engine.
Chris Cope
91 911 Turbo
Lyons, Colorado
Old 04-24-2006, 12:29 PM
Counterclockwise?
Can I ask the obvious question.
Has anyone ever heard of an engine being damaged by jacking?
Rod
1986 Carrera
2001 996TT
Old 04-24-2006, 12:52 PM
defcon65's Avatar
Thanks for the opinions, all and the link to the thread, Mike. I SWEAR I did a search first but didn't find that thread. I have to admit I've already jacked it up by the engine but was struck with the uneasy feeling of 'there has to be a better way'. Years ago I remember seeing a guy on Late Night stop a metal-bladed fan safely with his tongue - twice, but thought that it just wasn't right...
I guess I'll have to buy that jack pad if I want to sleep nights.
Joe
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 04-24-2006, 01:05 PM
Automotive Monomaniac
Emission's Avatar
Great question.
Not me.
I put a rolled up newspaper under the case before I put my jack under it. It spreads the load a bit, and keeps from metal/metal contact.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-24-2006, 01:12 PM
vash's Avatar
i like that question! anyone ever heard of a motor being damaged by using it as a jacking point?
i do it all the time, and i sleep great!
poof! gone
Old 04-24-2006, 01:15 PM
Regenerated User
72doug2,2S's Avatar
I've done it, but it seems wrong. That's not a major piece of metal you're using and it certainly wasn't designed for it. I don't need to start any oil leaks I don't have, so I say no way. I purchased the jack pads and will lift her one side at a time.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 04-24-2006, 01:18 PM
dogpie
Guest
Posts: n/a
a hockey puck is my choice, it fits right in the floor jack pad
Ever see a engine that leaks oil?
The amount of deflection is not going to be an observable phenomenon without pretty precise measuring equipment. But it wouldn't suprise me if an engine that lifts its car regularly leaks more than one that doesn't.
"Rust never sleeps"
For 20+ years I lift the rear at the engine case; however I always put a softener (piece of 2x2) between the jack and case = no problem.
Old 04-24-2006, 01:30 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
+1
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 04-24-2006, 01:32 PM
vash's Avatar
no way. the pistons swing back and forth has to be more than 1500 lbs of dead weight. and i promise any internal dynamic loads is alot larger than what that bar holding the motor to the motor mounts sees. that thing is thin! it would govern the max capacity.
poof! gone
Old 04-24-2006, 01:33 PM
Counterclockwise?
I use a 6" piece of 2 x 4 that has crushed itself to form the basic shape of the engine.
As the engine itself is most of the weight of the car, would this not be the same as sitting the engine on the floor?
I have no leaks.
Rod
1986 Carrera
2001 996TT
Old 04-24-2006, 01:37 PM
Emission's Avatar
"As the engine itself is most of the weight of the car, would this not be the same as sitting the engine on the floor?"
That's part of my justification - the engine is nearly all the weight back there.
One downside - it could stress the engine mounts.
Old 04-24-2006, 01:44 PM
Counterclockwise?
All in all this a very safe practice. IMO
I never have a good feeling about jacking one side and then another.
Rod
1986 Carrera
2001 996TT
Old 04-24-2006, 01:53 PM
Kantry Member
oldE's Avatar
I have a piece of 2x6 with a relief cut for the drain plug. It spreads the load out along the centerline. No problems in 6 years.
Les
Best
Les
Old 04-24-2006, 01:55 PM
Jack by engine with no problems. I use a thick phone book for a pad.
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 04-24-2006, 05:21 PM
Is it not recommended to jack using the trailing arms? A low profile jack could easily get under them and lift the car as high as you need. Does it set off the alignment? Or dent the arms? Just curious really. It doesnt seem to me that it would be any worse then using the engine. They do hold the car up after all.
Mike.
1972 911T, non-sunroof coupe.
Old 04-24-2006, 06:54 PM
