Bird like sound
Hello everyone, I recently replaced the front wheel bearings. Now I'm hearing a high pitched sound. It sounds like a bird chirping as I speed up or as I am slowing down. Could this be the wheel wheel bearings I just replaced?
Thanks, |
Tight brakes barely rubbing ?
did you grease the lip of the seal?
Daniel, I will check that out today, John, I did but could it be that I did not put enough grease on it?
Thanks, |
Daniel, you were right on the money.
Thanks Brother, |
Btw; do not reuse those damaged new wheel bearings.
| All times are GMT -8. The time now is 04:13 PM. |
