How do you like your scissor-lift? Does it raise and lower precisely? i.e., like a typical hydraulic jack where the user can control the speed as it lowers.
Does the lift provide enough room, height as well as general lift clearance, to drop an engine and transmission? Thanks, Steve |
The 961 http://forums.pelicanparts.com/uploa...1274418083.jpg |
Unfortunately, the 961 had to be run at a higher-than-optimal ride height, which compromised the looks. I think it had to do with a flat undertray regulation. I will have to review the Norbert Singer book.
Remind me not to get a flat in a 959!
Thanks for the update Wayne, keep em coming. |
:) Wait until you guys see the next project car! -Wayne |
-Wayne |
-Wayne |
I ordered one of these for the shop, it's not in yet: http://www.dannmar.com/dannmar-produ...-Post-Lift.jpg It's a portable two-post lift, it's very cool, and I think it will be what I'm looking for here at home. You can easily unbolt it from the floor and stash it away or move it to another bay or another side of your garage. -Wayne |
-Wayne |
http://forums.pelicanparts.com/uploa...1274431049.jpg I don't have time to depressurize the hydraulic system tonight, but I will probably be working on it tomorrow and over the weekend. I'll post pics! -Wayne |
http://www.pitstopusa.com/images/PLAWW-S-MED_MS.jpg I'm thinking a butterfly design would be the better way to go on the above to not bind the nut. Would it work? What an I missing? Modify this?: http://www.impaktrc.com/images/pro60..._wrench_01.jpg |
Found it.
http://www.kaedings.com/images/krp-wheel-knocker.jpg Quote:
(But I'm pretty sure it is planetary gears multiplying the torque - it has to have like 300+ foot pounds? The CGT has the same setup.) |
nevermind. ;) |
I could have used one of those after taking my truck in for tires. They must have rattle-jacked the nuts on @ 175 ft. lbs.!
Now. let's see.... we make an indexing five point insert and we are now 959 mechanics! ;) |
- Mike P.S. - I came across this thread while doing research for my story. SmileWavy |
Wow, it's been almost 3 years since I started this. In my defense, I've been pretty darn busy (we moved the entire company to a new location, which is what initially distracted me). I am happy to say that tonight I started working on this again. I'm headed up to Magnus' place in a week or so, so I figured it would be good motivation to get this thing back on the road and running again. I'll post some pictures relatively soon - I got the two front accumulators replaced out (2nd time) again tonight (the experimental ones didn't work out too well on someone else's car). More info on that coming soon.
-Wayne |
| All times are GMT -8. The time now is 03:11 AM. |
