Post Sleeve or rebore existing cylinders?
I am in the process of rebuilding an older '65 911 2.0 spare motor that will go into a '67 911S chassis, and was wondering if it was a viable option to sleeve or rebore the existing cylinders? This would seem to have the potential of saving a couple of thousand dollars since most piston/cylinder replacement kits go for $2,500 plus for these engines, if you can find them.
Can someone recommend a source if this is an option.
Thanks,
Don in Redondo Beach, Ca.
Old 06-26-2001, 02:04 PM
Senior Member
Leland Pate's Avatar
Post
Call or Email Engine Builders Supply, out of Reno, NV.
They will give you all of the options available to you.
I don't know allot about the cylinders out of that early of a car.
EBSRACING@AOL.COM
best of luck,
Leland Pate
___'99 Dodge Dakota <-which pulls the "real" car
___'79 SC Targa
Which hopefully will be back together soon...
Old 06-26-2001, 02:14 PM
Early_S_Man's Avatar
Don,
Yes, the Biral cylinders can be rebored up to 1.0 mm larger, and oversize pistons used to be available.
You may want to visit the JE Pistons website, or talk to them in person in Huntington Beach about their 9.5:1 forged pistons with valve relief cuts option.
www.jepistons.com
Warren Hall
1973 911S Targa
Old 06-26-2001, 05:38 PM
