tobluforu's Avatar
Cam towers for a 72
Well a rocker shaft walked out on me and now I need some cam towers. I know these are 3 bearing towers, but could someone tell me what years will fit a 72T mfi and a part number?
Old 06-03-2010, 03:49 PM
356RS's Avatar
69 up to the 4 bearing cam tower will work. Only difference is the camshaft bore end plug is removed on the left tower for the MFI cam seal. Casting numbers are 901 105 111 OR. You could even use two right side (same as left but plug installed) cam towers. Just remove the plug on the cam tower you are going to put on the left side and install the seal. Cam oil fittings may have to be swapped end to end. The cam towers are not hard to find and not much $$.
Mark Jung
Bend, OR
MFI Werks.com
Old 06-03-2010, 04:43 PM
tobluforu's Avatar
Thanks for the help! For some reason I was under the impression that mfi towers were special, but if they bored them all and plugged the non-mfi then this makes it much easier and cheaper.
Old 06-03-2010, 04:58 PM
