How to repair Tachometer Dampening
The tach on my 914/6 (conversion) has lost it's dampening. The tach needle is nice and steady as long as the engine rpm is constant. When the rpm changes quickly (such as when gear changes are made), the needle bounces. It takes a few seconds to settle.
I remember reading a thread about adding a resistor to the circuitry to repair the problem. I have searched and searched and can only find reference to bad grounds, voltage regulators and alternators causing the tach to bounce. This tach only bounces when the engine rpm changes quickly.
Even though a 3.2 six has been installed in the 914/6, the engine electronics and induction are still "old school" ... 40mm Weber carbs and points, condenser & CDI ignition. The tach is an early 70's 911 model with a 7,200 rpm redline.
Can anyone help me out/
Eddie
Old 06-17-2010, 11:39 AM
Northern Motorhead
wildcat077's Avatar
Eddie,
Save yourself the trouble of possibly causing more damage to your tach and send it out
to Hollywood Speedo to have it calibrated and dampened.
I think it's in the neighbourhood of $100.00 dollars ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-17-2010, 03:03 PM
dshepp806's Avatar
Originally Posted by wildcat077 View Post
Eddie,
Cheers !
Phil
100 % agreed, w/ wildcat077. Reduce that stress level.......they'll take care of you.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-17-2010, 04:32 PM
I received some info:
A 2200uF capacitor directly across the windings of the tach needle.
I will give it a try after a trip to Radio Shack.
Cheers
Eddie
Old 06-18-2010, 08:30 AM
304065's Avatar
Cheers
Eddie
I don't think that will work, it will mess with the timing of the monostable multivibrator. The tach dampening is mechanical.
Early VDO Tachometer Guts
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-18-2010, 09:13 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Pls keep us posted, as mine acts the same as yours... and I'm far awaaaaaay from Hollywood !
It would be nice if a simple capacitor would solve it.
Old 06-18-2010, 09:15 AM
