Born to Lose, Live to Win
ramonesfreak's Avatar
oil covered CV
was getting car inspected today by non-porsche shop and the guy noticed that the right CV was coated in oily grime..he suggested that there is a seal where the CV meets the transmission
is there a seal and is this an expensive fix for a porsche shop to do? any other thoughts. dont have time to post a photo just now but maybe later
my initial thought is, how much tranny fluid has leaked....but i have no way to get under car safely at the moment to check
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-20-2010, 01:06 PM
SirAndy's Avatar
Replacing the axle shaft seal is pretty straight forward.
The grime could also be a torn CV boot that is leaking CV grease.
Either way, a good Porsche shop should be able to fix this for you in under an hour.
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 05-20-2010, 02:01 PM
cool. so probably a $100 bucks or less
thanks
1983 911sc
Old 05-20-2010, 05:50 PM
Transmission flanges........
thanks
srandallf,
The oil seals for the transmission axle flanges are very easy to replace and they cost probably half of your budget. If the grime is caused by the transmission fluid, the seal is leaking.
Tony
Old 05-20-2010, 06:51 PM
thanks...i dont have access to a jack and stands right now...so this gives me an idea what to budget for my local porsche pro to fix...otherwise i would attempt it myself
1983 911sc
Old 05-20-2010, 07:04 PM
this has probably been going on for as long as ive had the car...4 years...i would guess
is this a disaster waiting to happen or should i take care of it pronto?
thanks
1983 911sc
Old 05-20-2010, 07:05 PM
SirAndy's Avatar
I'd take care of it.
If it's transmission fluid and has been leaking for 4 years, your transmission will be low on oil by now. Drain the rest of the oil and check the drain plug for metal shavings, replace the seal and fill it up with new oil.
If it's CV grease, you could blow up the (now dry) CV. Don't just re-pack it with grease, take out the balls and inner race and check for excessive wear due to running dry. The balls should go back into the same groove, so mark them before removal.
Andy
Old 05-21-2010, 10:25 AM
thanks guys. i made an appointment for next week to have it looked at.
1983 911sc
Old 05-21-2010, 01:08 PM
kodioneill's Avatar
How about a photo of the cv joint and surrounding area?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-21-2010, 01:16 PM
here is a photo. it doesnt look too bad but the other side is dry as a bone and looks new.
1983 911sc
Old 05-21-2010, 01:31 PM
kodioneill, im in upstate and also have a chiffon white car!!!
1983 911sc
Old 05-21-2010, 01:32 PM
kodioneill's Avatar
I would say the gasket for the CV joint to the flange is bad not the trans seal. I live near Saratoga. Where do you live?
1982 chiffon 911sc
Old 05-21-2010, 01:36 PM
Rochester
so does that mean its likely trans fluid or CV grease if it turns out to be the gasket as you say
1983 911sc
Old 05-21-2010, 01:48 PM
AutoBahned
RWebb's Avatar
bad gasket means CV grease leaking out
is there spray anywhere above?
I'd be tempted to clean it off well, check the torque on the bolts & see what happens after a drive.
Old 05-21-2010, 01:55 PM
there isnt much spray anywhere. i cant reach the bolts...i dont have stands or a jack...but i might be able to clean it....though if all the grease is gone i wouldnt expect to see much of anything
i wont drive much until i get it into the shop i guess
1983 911sc
Old 05-21-2010, 02:00 PM
that might be spray on the bottom of the tranny now that i look closely. crap
1983 911sc
Old 05-21-2010, 02:02 PM
im confused...this thread indicates the gaskets might not even be needed?
CV joints
1983 911sc
Old 05-21-2010, 02:11 PM
for cross reference: CV maintenance thread with pics
Constant Velocity Joint, CV Joint Service - Maintenance
1983 911sc
Old 05-21-2010, 02:29 PM
AutoBahned
RWebb's Avatar
stands will save you some $$ down the road; you can - carefully- use the emergency jack that came with the car to put it on stands
for now, just drive to the shop if you don't hear any noises
Old 05-21-2010, 02:35 PM
