-   -   To rebuild calipers or not to rebuild calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/543711-rebuild-calipers-not-rebuild-calipers.html)
sobamaflyer 05-21-2010 04:04 PM
When my car came to me it's brakes drug the rotors enough it didn't need the emergency brake on to hold it at a slight incline. The reservoir was bone dry (although there is traces of fluid in the lines when I removed calipers) and I can tell the MC had been leaking fluid all over my pedal cluster (another seperate issue).
I've now got in my hot little hands a brand new MC, big thing of super blue and a full set of caliper rebuild kits, braided lines and speed bleeders. (the hard lines actually look pretty decent).
Before I crack open the calipers, something I'm not jumping for joy to do for some odd reason, is it pretty well certain they needed to be rebuilt since they were engaged as they were, or was that a symptom of the other brake system issues & bad soft lines?
I really don't want to do this twice so if the concensus is nut up and rebuild them while they are off just tell me that.
Also, searching has thus far not told me just how to bench bleed the MC.
Thanks, Travis
Oh Haha 05-21-2010 04:29 PM
Rebuild them but you don't have to separate the halves. I did mine a few years ago due to one sticking and it was easy.
AFA bench bleeding the MC- take 2 lengths of proper size hose and attach them to the outlets on the MC, take the other ends and submerge them in the resovoir, filled with fresh fluid.
Move the piston in and out a few times or until no bubbles appear in the fluid. Keep the lines on but pinch them shut somehow until you attach the car hardlines. It's been awhile since I've so forgive me if I left out a detail.
herr_oberst 05-21-2010 04:33 PM
Do it!
And be sure to read the instructions carefully, the pistons need careful orientation in the bores. Ask me how I know.
JJ 911SC 05-21-2010 04:39 PM
I'm with you...
Travis
Just like you, I got all the parts for a re-build but I'm not sure I want to do it...
When I got Das Babe, the PPI list that she was pulling to the right under braking as well as the emergency brake did not work.
I had the shop do a brake job, the emergency brake was fix but not the pulling. In Wayne 101 Project book, he describe the same symptoms and mentioned that it's a rather easy project that people fears.
Now that I got a scissor lift, http://forums.pelicanparts.com/porsche-911-technical-forum/497020-joined-scissor-lift-owners-club.html, I got now excuse not to do it... might wait for the fall.
Go for it... and keep us posted.
J.J.
Oh Haha 05-21-2010 04:40 PM
yep, the piston position can be tricky but it's not a big problem with the help you will find here.
these are threads that have tons of good info and techniques for the job.
Pelican Parts Technical BBS - Search Results
James Brown 05-21-2010 04:49 PM
You will like yourself and so will your car, brakes will improve dramatically! and you will save some fuel.
RWebb 05-21-2010 05:04 PM
get the magic Porsche brake paste too
cyclistep 05-21-2010 05:41 PM
For what it's worth, I just recently had a sticking caliper. New fluid and lines solved the problem without a caliper rebuild.
vash 05-21-2010 06:18 PM
first dont crack open any calipers. all a rebuild is: slide out the piston, clean, put in new seal, slide piston back in, put on new dust boots..and you are done!
on that 75 car, do the calipers first. changing the MC is not hard, but putting on the brake fluid supply lines is an exercise in kungfu meets taichi, with JEDI master skills. you will be grunting with unZEN like fury. it isnt a good time. unless the MC is bad..i would avoid it. on my 75 car, it leaked fluid onto the floorboards. your floor dry? as a consultation prize, the 75 pistons are easy to remove..
one bottle of brake fluid aint gonna do it. i burned thru 3.
Zeke 05-21-2010 06:36 PM
Or, you could send your calipers to Goldline Brakes - Rebuilt Disc Brake Calipers and have a work of art not to mention the best working hardware.
sobamaflyer 05-21-2010 07:09 PM
Ok, coming inside for a quick bite, I was almost ready to come in and ask how the holy ^&%%$## you got the supply lines out but apparently my combo of cursing, thai-chi and kung-fu finally got it. You ain't kidding!
Yes, my floorboard is soaked and has the largest (still not awful) bit of rust on the car so far. The bushings in the pedal cluster are toast also due to the leaky old MC.
Thanks for the encouragement on the calipers. I tried moving them with compressed air, only 1 of the 4 wanted to move freely. I have the feeling that will be fun too. I'm going ahead with the matra of fix it all once and fix it right.
Oh Haha 05-21-2010 07:14 PM
Good for you!!!
You'll be happier and enjoy the car more when you KNOW the brakes will function properly.
If you get stuck, just ask. We'll get you through it.
tevake 05-21-2010 07:48 PM
Hang in there on the brake rebuild!!
I had all of the calipers off the car, and found that air pressure wasn't enough to move some of the pistons out of the calipers. So I reinstalled them on the car to used hydraulic pressure to free them up on the car. That worked great. And gave me practice in installing the calipers and bleeding the brakes. Made the final assembly that much easier.
You may have to deal with the MC to be able to proceed this way. I rehung the calipers without the rotors in place.
Also use 2x2 timber as spacers in the calipers to keep the moving piston in place while freeing the other. I used a very large adjustable wrench in place of a clamp to control the moving piston, while freeing the other.
Cleaning the cylinders and pistons, replacing the seals went pretty quickly.
some Hi temp paint made the calipers look good.
Do be careful there is a lot of pressure at play. The pistons can blow out like a shot.
I haven't done anything like this for decades, with the help of the forum and tech articles it went well for me and was very satisfying.
Good luck!! let us know how it goes.
Richard
http://forums.pelicanparts.com/uploa...1274495832.jpg
http://forums.pelicanparts.com/uploa...1274495901.jpg
vash 05-21-2010 07:55 PM
soba. i have a bike tire pump that i cut the tip of the hose. it is dedicated for 911 caliper rebuilds. if i remember correctly (i'll deny everything if you tell anyone:)), on the fronts, you can use two wooden dowels to pry up the pistons. i think the fronts have a "lip" you can grab. i used two wooden shims i had laying around. you need two, to form a fulcrum on each side.
good luck. you have passed the point of no return!! gooooo!!
wait until you want to put the input lines back in. breath in blue, breath out pink...repeat.
Flieger 05-21-2010 08:10 PM
Well, I am going to plug Eric Shea at PMB Performance for great brake work. www.pmbperformance.com
Wavey 05-22-2010 04:15 AM
Goldline also has a proprietery coating that is awesome. I had them do mine 5 years ago and the calipers still look new. If you care about that kind of stuff :)
Carrerax 05-22-2010 05:09 AM
+1 He does an amazing job.
