Antifreeze in Exhaust???
A few weeks ago, I jacked up my car to change the rear wheels and something black began to run out where the cat converter attaches to the tail pipe. I could have sworn it was antifreeze. Since then I've noticed the car running a little rough, especially at idle and also have noticed that it seems to be running a little hotter than normal, maybe 8 to 10 degrees more than before. Pressure test shows no leaks in system. Got me worried, but it still seems to run strong. What could this be?
3.4 Bigger is better
Chris welcome to Pelican. Congratulations on your new car.
![]() This is posted on the air cooled forum and not sure you will get much help here. No H20, LOL See if you can get a moderator to move it to the 996/997 board. It also helps to post your cars info in your signature so everyone knows what it is.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
