Picture of Correct Position of Leaf Springs in sunroof
I need a picture of where the long leaf springs are supposed to go after repairing my roof. Do they extend below the pins or not? My roof does not want to open after repair.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Recreational User
Not sure what you're talking about exactly....there aren't any leaf springs in a sunroof. A pic or diagram might be helpful.
Below the pins. The pins are forced downward, forcing the sunroof dress panel into place, as the sunroof travels forward and the rear lifts up into position.
Hope this helps.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Stibbich 6:11.13
+1 below the pins. They wouldn't do anything if they weren't, and they help smooth the transition from raised to lowered (and vice versa) at the end of sunroof travel.
Cheers! John B. Ellis 1983 911SC Coupe 1996 Jeep Cherokee Sport |
Still a bit confused since the pic doesn't show the spring on the pin. The spring should press the pin toward the roof, correct? ie goes between the headliner and the pin?)
