-   -   3.2 Carrera not running right after mods! (http://forums.pelicanparts.com/porsche-911-technical-forum/544203-3-2-carrera-not-running-right-after-mods.html)
tony9704 05-24-2010 02:14 PM
A brief history.....
'88 3.2 with 89,000 mi.
well maintained, doesn't burn a drop of oil
always ran like a new car. I run 93 octane
Than I did this...
Cat bypass, Dansk 1 in- 2out sport muffler, Wong chip (I thought the car would run sweet after these simple, tasteful mods)
Now it runs a little different. It pops when it idles down after revving it, and on deceleration. When I drive it slow, the idle sticks at 2,200 rpms even after you push the clutch in. A quick rev with bring the idle back down perfectly. When I do this rev, a small puff of smoke comes from the tailpipe. The car does not smoke normally at idle or during acceleration. The car at times actually feels like it has less seat of the pants power to me. I would think these mods would be good for 15-20 hp. I should feel that. Either way, the car is simply not running right. I'm guessing AFRs are screwed up but shouldn't the Wong chip have taken care of that? The car has fresh plugs, cap and rotor, fuel filter, air filter. I'm not quite sure where to start. Thanks,
Tony :confused:
geoz 05-24-2010 02:55 PM
Have you tried contacting Steve?
Justin@Athens 05-24-2010 03:17 PM
check the 02 sensor was not damaged during installation of cat bypass
I have the same MY and have a fluctuating idle as well. Also have a cat bypass w/stock muffler.
My chip is not SW, but the Russel Berry chip by MAXhpkit comes in 3 standard forms depending on exhaust type, fuel type, and air meter.
I'd look at your throttle assembly in the engine compartment to see if you are suffering from this problem
http://forums.pelicanparts.com/porsche-911-technical-forum/541862-big-scare-today.html
kodioneill 05-24-2010 03:29 PM
Make sure you did not bend a terminal on the prom when installing it .
tony9704 05-25-2010 03:20 AM
Thanks for the advice. I have not yet called Steve. I would like to try to solve this first. The chip install went very smoothly. I am certain I did not bend any of the legs on the chip. The O2 sensor is a different story. Those are always a pain. I used heat, penetrating oil, a pipe wrench and LOTS of bad words to get that thing out. So, how do I know if its OK? The inside of it looked good, just the outside (nut side) looks like it had been through the war.
If it makes any difference, the elevated idle gets worse as the engine gets hotter. It does not do it cold or warmed up. Just when the motor gets real hot. (and it has been warm here lately) Is there a way to check AFRs without a dyno? Thanks again,
Tony
WIL84911 05-25-2010 03:52 AM
I also get popping like you described - I think it's normal. Not an expert but it looks like readjusting idle mixture is first step due to new chip. I'm sure this is wrong but it works for me. I lowered the air & idle screw almost all the way down then increased idle a bit so that motor runs smoothly, then increased air mixture to normal level.
89911 05-25-2010 04:51 AM
I had Steve make me a chip(s) years ago when he was just starting. I originally had a MAF intake system that was nearly impossible to correct with different chip setups. We must of went over half a dozen chips before coming up with one that was suitable. Even so, I ditched the MAF and went with the stock intake and had some more chips made to work. My car is a 3.4, twin plugged, 20/21 cam, bored throttle body and Extrudehoned intake, and SSI's. Its not a typical set up and needed some custom work. Anyway, he got it tuned in and put down some nice numbers at a dyno. Lots a variables in making chips and the first thing I would do is get a hold of him, he knows what to do.
wildcat077 05-25-2010 06:31 AM
Tony,
I have an 89 with basically the same stuff as yours,my throttle would hang as well and i thought it was the SW chip causing this but it was the throttle linkinge where it attaches to the gearbox that needed some cleaning and lubing ...
Now with the warm weather,my car is doing it again and i will go in there and clean and lube again.There was roughly a 4000 km interval since the last time i did this !
Cheers !
Phil
NoLift911 05-25-2010 09:58 AM
Did you jumper B & C to correct the idle per the instructions?
Also if you are a California car did you disconnect the brown wire under your seat?
ischmitz 05-25-2010 11:37 AM
Just and FYI - if the chip would have been damaged (bent pins, etc.) the car would not even start. It is a black-and-white scenario. Once it fires up the chip works.
If your air/fuel ratio is off there can be many reasons for it. Intake leaks, exhaust leaks, bad O2 sensor, bad AFM, CHT, and the list goes on.
Then you could have knocked off a spark plug connector or an injector connector. Test these first to rule out the simple stuff.
Ingo
johnsjmc 05-25-2010 11:48 AM
I think there is also a micro switch on the throttle linkage at the throttle body. If it not working properly you will get idle running problems. Check the throttle linkage for full closing and listen for a small click from the idle microswitch .Even better to check it for continuity.
WIL84911 05-25-2010 12:48 PM
Yes. Thanks forgot that detail.
tony9704 05-25-2010 03:30 PM
Nice info as usual guys. I don't remember seeing anything about a b-c jumper. But this sounds like it may not be relevant if the car only does it when very hot. Correct me if im wrong, but the jumper would cause consistent problems. I'm thinking that Wilcat077 (Phil) may be on to something. I remember that I took some of the play out of the throttle cable a few weeks back as long as I was under the car. This may prevent the microswitch from actuating when I let off the gas. I will definately check this.
Brown wire disconnected.
ISchmitz- there seem to be a ton of things that you mention may cause these types of problems. Is there a good place to start? Common vacuum leak areas or something similar? I know that it was the work that was recently done that is what's causing the problems. The car ran beautiful before. Literally like a new car. Thanks
Tony
tony9704 05-25-2010 03:31 PM
BTW, does the jumper apply to my year? This is an '88 w/28pin chip.
kidrock 05-25-2010 03:50 PM
Tony,
the "jumper" everyone is referring to is actually a homemade wire that is used temporarily to adjust your base idle at your throttle body. The wire "jumps" holes B and C at a service connector underneath the black plastic cover next to the coil. Your base idle is usually adjusted after any adjustments are made to your air/fuel mixture at the air flow meter (AFM).
tony9704 05-25-2010 05:46 PM
I see. It seems as though base idle is fine. The problem is probably a sticky throttle cable or too tight of adjustment to hit the idle switch. All good ideas though. I always learn so many other things in searching for the anwers I need.
WIL84911 05-25-2010 06:06 PM
Yes base idle may be fine but stays high at times which was my problem. I fixed it by adjusting idle/air mixture and to properly do this you need to disable the volumetric control system hence jumper of B & C on left side of engine compartment. Invest in 101 Projects book.
88-diamondblue 05-25-2010 09:25 PM
Contact Steve as he will have valuable input to finding out what is going on. BTDT and the knowledge that he contributes is priceless.
As for the smoking your valve guides are very likely worn. If you removed the cat for the pre-muffler you will see the smoke that the cat burned up. I rebuilt my engine at 88,000 due to two broken head studs and worn valve guides. Mine didn't show any smoke until the cat was taken off. Beware of the "while you are in there addiction":D
89911 05-26-2010 04:18 AM
Why not go with the obvious? If your car was running fine before and the only thing you did that would change these issues is the chip, why chase other factors? The exhaust changes won't cause the problems you have. There are several factors in chip construction, spark advancement, fuel ratio mixtures, and more. I would think one of these is not correct for your specific car.
WIL84911 05-26-2010 04:34 PM
Something like this I backtrack & check everything I did. I do it more than once if necessary. You might surprise yourself. Hope this helps.
tony9704 05-26-2010 04:51 PM
Is the only way to check air/fuel by way of dyno? Can any shop hook up a computer for a printout that Steve could translate into a new map? (I suppose I could just ask him.)
Also, you guys are freaking me out with all the broken head stud and valve guide stuff!
A bit more history, the top end (including guides) was done 20,000 ago. So I'm hoping the puff of smoke after settling down the idle is just bad combustion.
88-diamondblue 05-26-2010 05:45 PM
Dyno or something like the LM-1 or 2 from Innovate Motorsports to get Steve the AFR's. I used the LM-2 to figure out what my problem was. Cam timing was off due to me timing it wrong. With Steve's expertise and patience the car runs great.
Shouldn't be any issue with the guides since your top end was done such a short time ago. Wasn't trying to scare you just didn't know what had been done to your engine.
89911 05-26-2010 07:13 PM
I didn't ask you but do still have your old chip? If so, replace and see how it runs.
tony9704 05-27-2010 08:13 AM
I do still have my old chip. Wouldn't it run out of sorts with free flowing exhaust and stock chip? I guess it would be worth a try. You guys don't think that running 93 octane in a car chippped for 91 could cause some issues with driveability?
tshih 05-27-2010 08:20 AM
Running 93 octane in place of 91 octane only gives potential power gains and less possiblity of pinging/knocking. The engine should run fine if the chip is stock and you've mod the exhaust. We're talking about smooth running versus rough running not getting maximum power/torque from engine.
stlrj 05-28-2010 11:59 AM
Than I did this...
Tony :confused:
The first thing I would check is your idle contact and make sure it closes consistently. Also, the tailpipe smoke may be an indication of an over-rich mixture. These chips do not always pass smog due to rich mixture tuning causing many owners to resort to the original chip.
Cheers,
Joe
BGCarrera32 05-28-2010 12:18 PM
So basically you changed 3 things, and then noticed the problem. Start by checking out each of the 3, not chasing everything else under the sun first. The exception would be the throttle linkage, if by chance you jacked the rear of the vehicle up under the engine and caught the linkage, but bending the throttle sounds like a stretch to me unless you had the jack way up under the transmission or something stupid.
You car will be safe going back to the stock chip with your new exhaust and I would start there. Nothing to lose- see what it does and how it behaves. If it goes back to normal- there you go. A more open exhaust with larger tip diameters (or not) may sound raspier/throatier/louder and pop more. Get used to it.
O2 sensors are fuel trim devices that adjust the chip's fuel map slightly one way or the other to optimize power and fuel economy. When you start your car, the 02 sensor is ignored for the first 60 seconds or so anyway. Completely disconnecting it will put the computer in "open loop", which will not hurt anything except a bit of fuel economy and some optimization of the mixture. Not a big deal. Try completely disconnecting it and see where you're at. Euro Carreras of the 80's don't even have 02 sensors... ;)
My experience: continuing to lean the engine out will also cause exhaust popping noises. You need to find a shop with a "wideband 02 sensor" (specifically ask for this on the phone, if they go "huh?" hang up and try elsewhere). This is what the LM-1 and LM-2 are that 88-diamondblue speaks of. This will tell the tech right away where the base mixture setting is and it can be adjusted via the air bleed screw that is hidden underneath the AFM (it is a 3mm hex). Do not dink around with this screw until you have the wideband meter hooked up.
Steve's chips are generally very good ( I have done 3 with him) but they assume you have a properly adjusted, well tuned engine.
Good luck
BG
ALXinNZ 05-28-2010 01:15 PM
Dont panic!, This is but a small issue that will be resolved in due course and be an awesome story to tell and the next P-car meeting.
I have a Steve Wong chip in my car and its awesome!!
Not sure of your year with regards to wiring but I disconnected a brown wire under the seat for the smog restriction. It is just a plug on my car and a seperate wire on the loom into the ecu.......
Regards
Alxhttp://forums.pelicanparts.com/uploa...1275077736.jpg
tony9704 05-28-2010 04:31 PM
Thanks for all the great info. I feel like I have a place to start now. Thanks especially to BG for the thourough info!
dw1 05-28-2010 08:27 PM
I have an '87 with the Dansk 1-in-2-out and 93 octane SW chip (and Fabspeed euro-style premuffler). I have none of the problems your reported, and did nothing special when I installed these upgrades. I did, however, install a new O2 sensor (purchased at a local chain auto parts store).
I don't have much to add to the very good previous posts except to point to the DME troubleshooting flowchart in the "tech info center" of this web site.
The obvious stuff are things like vacuum leaks, bad O2 sensor, bad plugs and/or plug wires, etc., are of course the first things to check.
In addition there are some AFM check/calibration instructions at Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk Yes, this is on a 944, but the instructions still apply.
Searching this board finds a LOTS of info on Motronic troubleshooting.
Good luck!
-Dan
'87 black/black sunroof coupe w. f/r spoilers, fabspeed premuffler, dansk 1-in-2-out, sw chip, euro ride height, bumperette removal, CRD-220, etc.
tony9704 05-08-2011 08:50 AM
Just to update for future troubleshooters- The plug wires looked good and passed the "lights out" test, however, the cars issues sorted right out after changing the wires. (just the wire, not the end connectors) There must've been a faulty one somewhere, causing a stumble- Ben at M+K noticed it. I didn't even realize there was a stumble present, I just thought that was how these cars ran. Also, the problem could've been between the end connectors and the plug wire. You can't see how corroded or worn they are because they are inder the boot. Car runs crazy good now.
tony9704 05-08-2011 08:54 AM
Idle issue was exactly as thought- unrelated. The throttle cable was not letting all the way off. It only happened when it is very hot out. A bit of penetrating oil and the problem cleared.
This would be the first thing I would check with an overactive idle because it was such an easy fix. You dont even have to jack the car up to see and spray. Thanks again guys.
tony9704 05-08-2011 08:56 AM
I'd like to thank Wildcat077 for turning me in the right direction on the idle issue.
pixxi 05-09-2011 04:35 PM
Hi Tony, can you describe specifically the stumble that you mentioned, which was solved with new ignition leads? I have a stumble also with my '87 3.2 right now. Mine was first noticable only rarely, and only when accelerating hard through 2nd gear. Then over a few weeks it became continuously more noticable, even at less throttle and also in other gears. Any thoughts appreciated!
- Brian '87 3.2 Targa
s5uewf 05-09-2011 07:08 PM
You have to reset your CO levels. Before your mods, your car had a more restrictive exhaust system and more conservative timing and fuel map. Introducing these changes likely has altered your engine's baseline CO measurements, which means your air fuel ratio is off. Popping on deceleration could be an indication of the mixture being off, for example.
You should check your CO levels / Air Fuel Ratio.
Also, you may have introduced an exhaust leak when swapping out the exhaust. Listen and check for a leak. One easy thing to check and eliminate as a contributing factor.
Good luck - easy things to adjust and then you wil be all set.
tony9704 05-10-2011 03:08 AM
Hi Brian, Like I had mentioned, I hardley even noticed it at first. Someone else pointed it out. Car started and idles decent and ran out nice. The stumble made the car sound a bit more muscle car at idle . They should however, run smooth and consistent. as a remedy, I did a bit of maintenance- cap and rotor, leads. Mods are going to change things a bit. In my case, a problem that was present was amplified. The leads took care of it though.
pixxi 05-10-2011 10:55 AM
thanks Tony! I will check it out.
Cheers, Brian '87 3.2 Carrera
pixxi 05-27-2011 11:02 AM
Hi folks, thanks for the inputs.
The new wires solved it ! Yay. In love again.
Interestingly, I did not see any sparks initially after several checks in the garage in the dark, until finally spraying somewhat more generously some water mist along the wires - then finally I did see very faint intermittent sparks in the area where the wires run around the top of the fan shroud. :-)
Just for fun, here are some other steps I took prior to detecting and ordering the new wires:
- checked the AFM voltage output consistency using the 9v battery test per the944.com info thread; the process turned out to be quite simple and not very time consuming at all. Was all ok. I didn't open the afm, or clean or move the arm. I simply observed very consistent voltage increase with no drops, when opening the flap verrrryyy gradually.
- checked the O2 sensor voltage output, and it was also ok, ranged approx .1v to .8v per the related threads. The only tricky step was contacting the voltage meter electrodes to the o2 plug. Was glad it determine that it seemed fine.
- Found a vacuum line hanging behind the airbox area, which had disconnected from the y connector behind throttle body. Reconnected that, but did not notice any running change really.
Anyhow, problem solved in the end, thanks Tony.
Brian
'87 Carrera
dshepp806 05-27-2011 02:41 PM
NICE!!!!!
Doyle
