-   -   Engine and Trans mounts Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/544258-engine-trans-mounts-questions.html)
da Vinci Dan 05-24-2010 06:47 PM
It looks like these are the same part - is this correct?
Also, am I right in thinking that there are 4 for the engine and 2 for the trans?
Does any one know the torque specs?
Thanks for the help!!
-Dan
Flieger 05-24-2010 06:50 PM
2 engine, 2 trans, same part. You can use different hardnesses of aftermarket components if you choose.
edited thanks to Oh Haha :o
Oh Haha 05-24-2010 07:12 PM
You need 4 TOTAL. 2 for the transmission and 2 for the engine.
I installed the sport mounts and they worked well for me. Mostly street driving.
da Vinci Dan 05-24-2010 07:43 PM
Thanks - I was just about to order 6. You guys are great!!
What is the real difference between OEM and sport?
enjefriy 05-24-2010 07:48 PM
sport has less compliance compared to the OEM. The sports hence droops lesser, and locates the engine/Tranny in a more rigid manner by comparison.
Interms of engine vibration transmitter onto the chassis, it has been said that a bit more would be transmitted thru.
Thou i couldn't tell actually.
But I'd still get the sport. Great balance for my street machine as it doesn't compromise comfort to me.
RWebb 05-24-2010 08:02 PM
2 levels of Wevo also - if the sport mounts are too soft for you
mix & match fwd and rear (engine: stiffer) to get what you want
don gilbert 05-24-2010 08:08 PM
I put the sports in mine and like. I think they came on cabs as standard equip.
