Laneco's Avatar
3.0 Engine Stalls when Oil Cap Removed
The bone-stock 1981 3.0 in Butters is running great - I've been terrorizing the back roads and using it as a daily driver. Had the C02 professionally set, timing checked (I already had it right etc), idle speed rock steady 950.
Car runs perfect under all conditions. Then this today...
Went to check the oil level, warm oil, engine idling, level ground. I pulled the oil cap off, and the engine stalled. Tried to restart it with the cap off - no go. Put the cap back on - fired immediately.
Repeated twice more with exactly the same results. I've had some where the RPM would drop, but stall? Why? Have I done something stupid? (I mean stupid on this particular point, I do plenty of other stupid things...)
angela
Hello
Old 03-15-2008, 02:20 PM
Angela,
You are missing the vacuum restrictor thats supposed to be in the oil tank vent hose going to the airbox.
I have one if you need it.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-15-2008, 02:22 PM
Laneco's Avatar
Okay to drive it to Seattle on Monday? I could stop by on Monday and pick it up. Honestly runs perfect until I do this!
angela
Hello
Old 03-15-2008, 02:41 PM
angela
Oh my yes,... No problem at all.
Its simply frustrating to be unable to check the oil level.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-15-2008, 03:19 PM
Laneco's Avatar
Just a follow up on this post.
Thanks Steve - I put the little doohickey in and that's exactly what was wrong. It was a pleasure meeting you and talking about cars.
Butters says "thanks" too!
angela
Hello
Old 03-27-2008, 12:48 PM
Steve, if Angela showed up at your shop in a different car, would you say, "I can't believe it's not Butters!"? Just askin'.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-27-2008, 01:00 PM
Laneco's Avatar
BWAHAHAHA!!!!
The collective kindness and knowledge of the Pelican Gentleman is only exceeded by their extraordinary wit!
angela
Hello
Old 03-27-2008, 05:44 PM
Brian
That should get you banned for life
O2 In Sully We Believe
Old 03-27-2008, 06:14 PM
4flyboy's Avatar
I'll second that but I did giggle.........just a little!
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 03-27-2008, 08:24 PM
Brian
I can't believe you actually said that,.....ROFLMAO,...
(made my day!!)
Angela,
It was pleasure meeting you as well, and I'm glad that did the trick. It isn't every day that a cheap doohicky does the job,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-27-2008, 11:10 PM
3.2 CAB's Avatar
Yup, sometimes all it takes is a cheap little doohicky!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-28-2008, 11:36 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
It may be a little doohickey, but it certainly isn't cheap!
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 03-28-2008, 12:38 PM
pete917's Avatar
how much are they out of interest
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 05-23-2010, 04:26 PM
brads911sc's Avatar
$12.26 from dC Automotive.
$14.00 from our Host...
930-107-289-00-M260
Not what Id call expensive...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-23-2010, 06:37 PM
Can you provide the part number? My car has the exact same problem.
Old 05-24-2010, 03:20 PM
Zeke's Avatar
930-107-289-00-M260
that is the PN. the M260 suffix only means it comes from a non PCNA parts distributor.
Old 05-24-2010, 04:32 PM
pete3799's Avatar
Am i the only one who'd like to see a picture of Angela's doohickey.
Pete
79 911SC RoW
Old 05-24-2010, 04:48 PM
Remove the hose from the air box and insert the vacuum restrictor at the tip of the hose?
Old 05-24-2010, 07:04 PM
brads911sc's Avatar
No. I think the restrictor goes at the other end of the hose... not where it connects to the air box...
Old 05-24-2010, 07:06 PM
Old 05-24-2010, 07:25 PM
