-   -   passenger side power window switch (http://forums.pelicanparts.com/porsche-911-technical-forum/544435-passenger-side-power-window-switch.html)
bruni911 05-25-2010 05:16 PM
Hi guys i am so *^&(&(* frustrated my power window for the passenger does not work either on the drivers side and the passenger side just my drivers window works i have bought new switches and still nothing i think they are wired right could it be the window regulator, just do not know black on black no air its very hot...
Thanks Dave
pete3799 05-25-2010 05:38 PM
Have you verifyed that the window motor is OK?
bruni911 05-25-2010 05:44 PM
how can i verfiy the motor is ok?
86 911 Targa 05-25-2010 06:47 PM
Thanks Dave
Dave,
Let's begin at the beginning.
What is your model/year?
Do you have a Bentley?
And,
Do you have a meter?
Gerry
bruni911 05-25-2010 06:53 PM
okay
1987 930
no i have no bentley manuel
i will buy a meter tommorrow
i have a extra motor but no sure if its for the drivers side or passenger?
I know it works but not sure the side is there a way to tell?
schumicat 05-25-2010 07:13 PM
you need to apply power and ground directly to the wire connections on the window motor itself (using jumper wires). that will tell you if the motor works.
wildcat077 05-25-2010 07:39 PM
Bruni,
I had an issue two weekends ago where i removed the door panel to change the speakers and my passenger door window would not go up or down anymore...Wasted a whole afternoon trying to figure it out,testing for power,switches,etc...
Turns out the wires on the connector plug that goes to the motor were pulled really tight and were not making good contact.
The connector is approx 4 inches above the speaker hole,locate it and make sure the wires have enough looseness and are not nearly pulled out of the plug like mine were.
That solved the problem for my window.
They were intermittent for a while before that and slamming the door harder than usual would make them work,although that is not a recommended fix ... lol
Cheers !
Phil
86 911 Targa 05-26-2010 06:55 AM
Originally Posted by wildcat077 (Post 5370724)
Bruni,
Cheers !
Phil
Bruni,
This is worth a try prior to buying a meter.
I do recall passing this suggestion on to wildcat a few weeks ago.
The connector/wiring harness does tighten up over time.
As always, please let us know what you find.
Good luck,
Gerry
woland 05-26-2010 08:27 AM
Hi Dave
Assume that normally the engine works
To test it, you have to connect the green and black wires coming to the switch with an external 12V power source (ex. a battery charger). It's indifferent if + and green or + and black:
With the wires in one position the window goes up, with the other goes down
http://forums.pelicanparts.com/uploa...1274887128.jpg
When you verifyed the engine you have to verify the wires
The power of the passenger engine comes PRIOR to the driver side and THEN to the passenger door through the hood.
Under each fender near the door hinge there's a soket. Disconnecting it you can verify that there are no cracks in the wires testing the contacts one by one
http://forums.pelicanparts.com/uploa...1274887181.jpg
Normally, I use a 4 meters long external wire and an ohmeter: connect the extremities of each wire to the ohmeter and verify if the contact closes. In not, a wire has a crack.
The cause is opening and closing the door for 28 years :)
If every wire is ok, you can check the switches. But you tell you have changed it
Hope I have been useful
wildcat077 05-26-2010 09:07 AM
Gerry,
Thank you for your help,along with all the others who chimed in for my power window issue... I won`t mention the part about trying to manually lock my door with the driver`s door open... That`s another adventure altogether ... lol
Reading could be the best repair procedure !
Cheers :)
Phil
