-   -   Is this an "S" version--Need Help with Serial Number!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/54448-s-version-need-help-serial-number.html)
RonD922 12-15-2001 07:08 PM
Hello,
I finally got my 66 911 on the road today and I had the left front claiper lock up so bad I was running on 3 wheels going 25 MPH. Anyway I was about to order the rebuild kits for all 4 corners when I realized I am not sure whether it is a base model or "S". It came "S" combo gauges which I believe are orginal so it got me wondering??
Serial Number --303089
Please I need some help because I am ready to get caliper rebuild kits and new pads but I need to know for sure the model designation!!
Thanks For The Help,
Ron
GIBSON 12-15-2001 07:24 PM
Ron, looks like a '66 "normal". Check this page for more info.
http://www.early911s.com/
Bruce Herrmann
emcon5 12-15-2001 07:29 PM
Ron, If you are going to keep your 66 you probably ought to change your sig.
Tom
dbanazek 12-16-2001 04:40 PM
I would check the calipers, even if it is or is not an S someone could have changed the calipers. S has aluminum calipers check with a magnet, no stick = S calipers. It also has a 3.5" bolt spacing where the caliper mounts.
