mm86911's Avatar
Recaro Seat Mounting
So I finally received the Recaro Sports (90 days backorder) and installed them with Racaro rails. Look awesome and very comfortable. While they sit a bit lower than stock (good for helmet clearance but not too low) the bases seem too "flat" - the front of the base should be tilted further upwards to support the thights and better feel while seated.
Has anyone experienced this with aftermarket seats and what did you do?
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 12-16-2001, 10:46 AM
The mounting adapter bracket that bolts to the chassis and then the sliders bolts to it has three seperate openings to raise or lower the back or front. I'm not sure with your set up what you used. If you have a more race oriented seat (one piece), the seating position can be pretty uncomfortable for anything else other then track driving.
Old 12-16-2001, 12:59 PM
mm86911's Avatar
89911 - seats are Recaro Sports - pull-out thigh support, adjustable lumbar, back adjust and tilt for rear seat access. I used the Recaro rails and bolted directly to brackets on the tub. Are you saying there some sort of spacers that allow vertical adjustment of seat base?
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
Old 12-16-2001, 03:48 PM
