-   -   Could a bad alternator cause gauges to stop working? (http://forums.pelicanparts.com/porsche-911-technical-forum/544963-could-bad-alternator-cause-gauges-stop-working.html)
rennch 05-28-2010 11:33 AM
Just wondering if that could be the reason for my car's flakiness..
Targa Me 05-28-2010 11:37 AM
In all my years I've never heard of that.
I do know that these cars are very finicky when it comes to grounds.
rennch 05-28-2010 11:43 AM
Ok...thanks. The mystery continues.
darrin 05-28-2010 11:44 AM
a bad voltage regulator fried my tach (and my dme) on my '86 carrera. North Hollywood Speedometer fixed my tach for me and I was able to get my dme re-soldiered.
So, yes, it can happen, especially if the alternator's voltage regulator is failing and spiking high voltage through the electrical system.
rennch 05-28-2010 11:47 AM
Its not just my tach...all my gauges aren't working at the moment. They are spiking. Meaning, I turn the car on, and they pin out. My tach was weird...I was on a drive, and it became intermittent...then stopped working entirely.
darrin 05-28-2010 11:53 AM
What's your car's voltage when the engine's running. A bad voltage regulator will cause it to fluctuate into the high teens, which can fry stuff that's expecting low teen voltages. Your description sounds more to me like a grounding issue
rennch 05-28-2010 11:56 AM
My voltage running is around 11.8, which led us to believe the alternator wasn't doing anything.
dshepp806 05-28-2010 02:10 PM
11.8 VDC with engine running? you've your answer right there. Glad it's not an overvoltage condition.
Best,
Doyle
rennch 05-28-2010 02:18 PM
Which brings me back to the original question...could that cause gauge weirdness?
donporfi 05-28-2010 02:41 PM
Check the grounds, probably the instruments have a common ground which must be disconnected.
rennch 05-28-2010 03:24 PM
Checked those, all fuses, and have done a ground test on the gauges. All checks out...
pete3799 05-28-2010 06:44 PM
As Doyle said either your alt. or regulator is bad.
Should have around 12.8 volts or so running.
Don't know if this will fix your guages but i'd fix this first.
tcar 05-28-2010 07:00 PM
Michael,
You should have 13.5-14.5 V when the engine is running.
11.8 is too low with the engine OFF.
Your voltage regulator is toast.
I'll bet fixing that fixes everything.
I had a bad alternator and gauges were spooky, the wipers turned on by themselves, etc.
I don't know the extent of your electrical changes (you have a '69 with a 3.0 CIS, right?) I'm guessing you have the new VR that's integral with the alternator, behind the fan.
Your 69 would have originally had a separate VR on the left firewall by the CD ignition.
