77 930 automatic heat
Can't turn off heat on diver's side. Used to be able to just use manual control but now it's stuck. Both heater boxes open. Thanks.
the boxes need to be completely open so the inner flap seals off the heat. gotta still be leaking if you have heat. rusty, cable too tight, return spring off, etc?
