-   -   So what's the difference (http://forums.pelicanparts.com/porsche-911-technical-forum/54527-so-whats-difference.html)
Inari77S 12-17-2001 03:38 AM
... between the 74-75 turn signal switch 911-613-305-00
and the 76-89 turn signal switch 911-613-305-01.
I need to replace mine (high beams come on when I pull the lever, but wont come one when I push the lever.)
Seems both styles are available on ebay from time to time.
I'm guessing they're mechanically the same, but something must have changed.
TIA
cary 12-17-2001 04:20 AM
That is a serious wear part. I'd buy a new one. Wayne sells them right here on this site.
Not exactly sure, but I think the handles a little different.
You can go in and tinker with the contacts. But it sounds like yours is worn out.
My .o2c
Superman 12-17-2001 08:25 AM
You can get at those contacts with a fingernail file. Steering wheel and plastic pieces must be removed. I've 'fixed' mine twice. The second time, I installed a relay kit and I don't expect any further problems. The reason they fail is because all that voltage is going through the switch. The relay kits solves that design problem.
Roland Kunz 12-17-2001 08:50 AM
Hello
-75 has a slim stalk
76 on the paddle style end
john walker's workshop 12-17-2001 09:30 AM
often the plastic slider that moves the contacts is melted beyond repair, because of the current draw of 100W lights, which need to be relayed.
