83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest Brake ID Please
The car is a 1983 SC but was upgraded to a 3.2 and wide body rear end among other things.
The Disk diameter are 113/8" and the remaining thikness is 13/16".
The caliper are mark as follow:
Driver side: ??? P 81
Passenger Side: ??? P 82
Are these original SC or Carrera upgrade?
I left the wheels off so I could check for more marking if requires.
Cheers
J.J.
Who Will Live... Will See
Old 05-30-2010, 03:22 PM
Looks and sounds like stock SC calipers & rotors.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-30-2010, 04:13 PM
JJ 911SC's Avatar
Porsche Crest Just Getting Ready for a Turbo Upgrade
Hi Steve
Until I do the Turbo look upgrade, I bought all the parts to change the lines and re-furbished the calibers (I'm pulling on the right side under braking).
Having a cross over car (aka Frankenstein) I check the CATs and if I'm not mistaking the front are the same for the SC & Carrera but the rear are different.
So if they are SC, I got the proper kit.
J.J.
Old 05-30-2010, 05:23 PM
JJ,
Front SC and Carrera calipers have the same size pistons; only the widths are different due to rotor thicknesses (20mm vs 24mm).
Rear Carrera calipers have bigger pistons and the same thickness rotors (24mm) as the fronts.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-31-2010, 12:41 AM
JJ 911SC's Avatar
Porsche Crest I'll be set soon
Hi Steve
From my thickness measurement, using a dialed caliper, I got 20.6375mm (13/16) left which is thicker than new SC Rotor thickness (20mm) and they got at least 3500 miles on them.
Is it possible to use Carrera rotor with SC Caliper?
J.J.
Old 06-01-2010, 06:34 AM
No. The Carrera rotor is 24 mm thick
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-02-2010, 07:00 PM
