Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
911 sc upgrades
Just now installing the pre 1974 non thermal ssi heat exchangers and dual in single big dump out muffler on an otherwise stock 1982 911sc. Looks like will add about 35lbs of torque? Seems high for an exhaust upgrade... anybody have any comments on what to really expect?
Also, thinking about replacing the stock csi with the six webber carb set up (40mm) and installing the pre 1974 distributor for proper curve ect. Anybody know if an otherwise stock 3.0l will see much improvement with this upgrade?
Thanks guys!
Mike, Regina , SK, Canada
Old 06-01-2010, 08:09 PM
Adding carbs to the motor, with the SSi's and a free flow muffler, will add between 25-30 hp total.
You cannot use a distributor from a 2.7 as the 3 liter dizzy runs counter clockwise. You can have your distributor rebuilt/ recurved by several reputable shops.
We use Aaron Burnham at Rennwerks in Camarillo
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
1973 911S Glacier Blue
Old 06-01-2010, 09:39 PM
Thank you.
Was miss informed about the use of the older distributor. Glad I didn't fork out the cash yet!
mike
Old 06-03-2010, 08:05 AM
racer's Avatar
i think a 10-15% improvement in exhaust is possible (heat exchangers, 2in-2out pipe.
I don't think just a swap to Carbs will do anything without a change to the cam to take advantage of the increased breathing. 40's sound small to me as well, I would think you would want 46s at least..
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-03-2010, 08:08 AM
3 restos WIP = psycho
kenikh's Avatar
SC cams and 40 Webers are fine on an 3.0L. If you up the cam the take advantage of the reversion resistance offered by carbs (say a mod-S cam), 46s are preferred, but the slippery slope is that in most cases with higher perf cam and higher revs, you'll need to upgrade your rods to ARP bolts. This can be done without cracking the case...a PIA, but doable.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-03-2010, 09:57 AM
Less brakes, more gas!
euro911sc's Avatar
Well you will have to do the pistons if you are upping the cams... CIS pistons are not well suited to high lift cams... So now you have changed pistons, rod bolts, cams, and intake... might as well just get a set of bigger cylinders and go 3.2l SS with it
Mike, there are several threads on SC engine upgrades from mild to wild on the engine rebuild forum check it out!
Michael
FOR SALE:
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'03 330i Family hauler w/ extras
Old 06-03-2010, 10:19 AM
kenikh's Avatar
Yep - duh; good catch. CIS pistons can accomodate up to a 1.25mm intake valve pocket cut into the piston bump to clear high lift cams. More than that and you compromise crown integrity. The good news is that you can also do this with the pistons in place. Check the "How To" below - pretty cool!
Another Technique for Piston Notching. - FordMuscle.com Forums
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-03-2010, 10:24 AM
joe payne's Avatar
Take 200 lbs. out of the car.
jtp911
Old 06-03-2010, 10:45 AM
Joe, are you telling me to go on a diet!! Ha! Ha!
Thanks guys! Think I may put the engine back in the car for the next season or two and save up the cash to do the 3.2 l upgrade and the carb upgrade at that time! Also thanks for the great links guys! this was my first ever post! Great info and kinda fun too!
Old 06-03-2010, 12:37 PM
An SC motor with carbs, SSI's and a sport muffler can be a very fun motor. Think 3.0E. After all, most the E's were faster than the S motor cars up to 100mph if they both had the same gears.
Keep the cams, they are a great mid range cam and fit the stock gearing very well. Maybe retime them to early 77 3.0 Carrera specs for bit of a bump up top. If it is a 80-83 SC open up the ports to 36mm.
I well tuned 3.0 can make 230-240 hp and dose not have the rod bolt issue the 3.2 dose.
Then get it down to under 2500lbs and it will have the speed potental of a 73RS touring. 2300lbs and you can match a 2.7RS light weight.
Old 06-03-2010, 01:24 PM
Another option for the dizzy is to have it locked out and use one of the new MSD units with digital timing.
Functions the same as running mechanical advance only and timing shouldn't drift. If you haven't upgraded to an MSD unit already, the cost difference is minimal and you'll shouldn't have to re-curve again (mechanically at least) if/when you change to carbs... or when good gas gets even harder to find.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 06-03-2010, 03:08 PM
Chris
I was a little scared about moving to the MSD ignition because of some earlier posts I have read. But have always been a fan of them in my North American track cars ( new to the Porsche, this is only my second full summer with her!) But I like your idea, how do you lock the dist. ?
Mike
Old 06-03-2010, 06:27 PM
Have it done professionally... definitely beyond my skill level.
The same experts who can recurve the dizzy can lock it out with a fixed advance. Its also a good time to have the all the internals checked, wear items replaced, etc.
You need to decide how much total advance you will want, as the MSD unit is actually variable retard so it initially starts out delaying the spark and reduces the delay as RPMs increase. Then you simply program the desired curve into the MSD unit and you are set. If you need to change the timing, simply reprogram the unit with a different curve.
Old 06-03-2010, 06:36 PM
euro911sc's Avatar
Hey Mike! Stop being a 'GUEST' and register Come on in and stay awhile... sounds like you will be here a long time.
-Michael
Michael
FOR SALE:
Old 06-04-2010, 06:38 AM
How do I register? I thought I was.... I have a "garage" and a user name am I just not logging in right?
Old 06-07-2010, 10:08 PM
euro911sc's Avatar
Mike,
Sorry... You are listed as 'Guest', cant receive PMs/emails/etc., your garage is not viewable, and your post count is N/A. Something is amiss Seems you are stuck half way to being a real member... Try logging out of Pelican completely and then log back in. This is not restarting the browser as you user name and pwd are probably cached. Hit the LogOut link in the upper right just above 'Rate Thread' and to the right of 'Quick Links'. After that I would try getting a moderator to look at it.
-Michael
Michael
FOR SALE:
Old 06-08-2010, 05:58 AM
Registered Misfit
Mark Morrissey's Avatar
Thumbs up
+1 on the upgrades.
My backdated 3.0 78SC has Webers, SSIs, stock cams, MSD box, a Sycip rally muffler and it screams. My weight is just under 2300; On the last rally I had NO problem keeping up with an IROC car and several other cars with 3.6 conversions.
Cheers!
Ordo Templi Moretti
911 hotrod -- 3.0L, lightened, abused with love
'74 914 bastard
Old 06-08-2010, 08:58 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
