-   -   Thanks for the pipe wrench recommendation to remove ball joint nut! (http://forums.pelicanparts.com/porsche-911-technical-forum/545894-thanks-pipe-wrench-recommendation-remove-ball-joint-nut.html)
grahamkissack 06-02-2010 05:42 PM
Someone on the forum suggested I try a big pipe wrench to remove the bottom nut on the ball joint rather than an air hammer or dremmel. I was nervous because there's only 1/8" of material to grab down there. But I tried it anyway by securely attaching the wrench then using a jack to lightly hold it in place. The nut came off easily with a 2 foot breaker bar on the wrench no problem at all! Best part is both nuts are perfect after the removal...no damage at all.
Thanks for the tip.
uwanna 06-02-2010 05:56 PM
Good job, I knew it would work for you if you gave it the old college try!
rusnak 06-02-2010 05:57 PM
That was me, you're welcome....pass that tip on.
btaft 06-02-2010 05:58 PM
That was my post originally and after great response I also tried the pipe wrench.
2 minutes of gentle prying! Thanks much!
grahamkissack 06-02-2010 09:28 PM
Thanks to everyone! Power of knowledge is amazing and this forum makes that transfer happen.
