alt. replacement
I plan on replacing my altenator. Is there anything particular that I should look out for? Is it pretty straight forward?
Old 12-17-2001, 06:26 PM
Roy M's Avatar
Dead easy - cover your rear panel as you will need to manipulate the fan / alternator out.
Check position of air diverter before taking out and replace in the same way
Make sure you don't lose the shaft key - how did I think of that!
Remove the alternator from the housing by drilling a shaft clearance hole in a piece of 4 x 1 timber and screwing the alternator bolt onto it - obvious when you see it
Don't overtighten the housing strap when you replace - I had no problems but I've heard you can distort housing which can catch the fan.
Don't think about polishing the housing and / or painting teh fan while they are apart - it can be addictive!
Good Luck
Roy
Roy
Old 12-17-2001, 11:47 PM
rob911's Avatar
Roy
That is one smart looking engine bay!
I guess that you've had the engine out to detail it like this?
Also how long has the fan been painted, I heard that most any pain/polish/finish on the fan and housing quickly gets dirty and/or tarnished.
Great looking car.
01 Maserati 3200 GT Assetto Corsa
84 3.2 cabrio - gleaming
99 Alfa Romeo 166 3.0 V6 super - still going
03 Fiat Punto 1.2
http://www.pelicanparts.com/gallery/rob911
Old 12-18-2001, 01:29 AM
Roy M's Avatar
Thanks Rob
Not an engine out job - just a gradual improvement on a decent base. Car has 94000 on so is used regularly. Fan is painted and you can see signs of degradation at the leading edge - some due to bad prep. This has occurred after about 3000 miles. Housing just polished - reasonably easy to keep clean.
I cover engine when washing which prevents water marks but it keeps clean when running.
Basically I just love the car so like to look after it!
Roy
Old 12-18-2001, 02:41 AM
