my car diesels
My new motor runs great till it warms up fully then it runs crappy then I sit let it idle 30 45 sec shut off and diesel. Ive cleaned and lubed the distributor vacumn doesent work. All new only 5 miles on motor. Still tring to figure it all out any suggestions...Thanks
Old 12-19-2001, 09:01 PM
Senior Member
Doug Zielke's Avatar
This "dieseling" usually occurs as a result of (glowing) carbon build-up inside the combustion chamber. Pre-ignition.
But seeing as how you say your motor is "new", there shouldn't be any carbon at all. So, I'd double check your ignition timing with a strobe.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-19-2001, 09:42 PM
Information Junky
island911's Avatar
Re: my car diesels
Originally posted by my72911t/rs
My new motor runs great till it warms up fully then it runs crappy . . ..
t/rs. . .does that mean someone has put in different pistons?
You may have very high compression due to different pistons. This can make it run great till it warms up. Then the combination of high compression (adding heat) and the hot engine cause pre-ignition.
Try higher octane rated fuel.
'81 SC COUPE
Old 12-19-2001, 09:59 PM
I put in euro 8.5 90mm pistons in with solex cams timing is set at 5* before tdc warm at idle th ecar has super unleaded in it. Anybody think of anything else???? Thanks Matt
Old 12-19-2001, 10:55 PM
Senior Member
Hello
Check your ignition, valve timing, injection timing and injectors.
Also check if the engine isn´t flooded with fuel.
Grüsse
Old 12-20-2001, 12:08 AM
