NEWFIE 69 911E's Avatar
Targa top won't stretch: NO SUN ! Alternative to dryer?
Weekend Project: Attempting to recover my Targa top using material from our host.
Following technical articles and posts found here, I decided to mount the side gutters first, so I have not applied glue to the front or rear yet.
Its quite cold here this weekend (as usual), so sun bathing is not helping to soften up the material.
I tried the dryer method, and the material does soften up and stretches easier but it cools off too quickly, with no time to perform the stretch required.
Problem is, I can get the front bead to line up nicely, but I can't get the material to stretch enough to line up the back bead on the corners; there is about 3/8" to go!
Seems I will need to remove the gutters and try again, maybe in August when it might be hotter!
Suggestions?
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 06-13-2010, 05:10 AM
brads911sc's Avatar
Id wait until its sunny and park the car with item laying out in direct sunlight for most of the afternoon. if it were over 85 that would help. Not sure how warm it gets up there.
Suggestions?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 06-13-2010, 05:38 AM
Thanks, but the temp right now is 14 C
Perhaps I'll try a hair-dryer!
1969 911E Coupe
Old 06-13-2010, 05:46 AM
DanielDudley's Avatar
If you have a big cardboard box, turn it over on the top and the covering, and blow a hairdryer into it through a hole. Heat the entire thing.
Make a small exhaust hole on the other side of the box if needed.
Old 06-13-2010, 11:39 AM
P-Car
woywitka's Avatar
Can you heat your oven to 125F?
Old 06-13-2010, 11:51 AM
Make Bruins Great Again
Por_sha911's Avatar
Use a small electric space heater with a fan.
Joe
Old 06-13-2010, 02:46 PM
I've been waiting to for this last step too! but now its too hot outside and its over 100 degrees!
Old 06-13-2010, 03:08 PM
Platinum Member
dad911's Avatar
Heat lamp or a couple of Halogen worklights? They throw off alot of heat.
Old 06-13-2010, 03:22 PM
