windshield gasket
Is thjere a front and rear gasket, I can install without the chrome sealer strips? Is this safe to do, I have heard you can install awire in its place, any comments? Thanks, Norm
Old 06-11-2010, 08:48 AM
Mark S
None available I'm aware of. Yes you can install a filler where deco goes I don't know about "wire " but would think if same thickness as deco flange you should be GTG. As you seem to be aware you MUST have something in the groove or bye bye windshield at some point.
Old 06-11-2010, 10:54 AM
kodioneill's Avatar
No , the trim actually holds the glass in the frame. You can replace it with newer style gasket, and glass that has no such trim/bead if you so desire. Use the search function, many posts about glass and trim.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-11-2010, 11:58 AM
