Any thing to look out for if doing valve adjustment with partial engine drop?
I have my engine partially dropped for doing some other things and was going to do a valve adjustment while I was at it. Obviously it would be a little easier. Would the fact that the engine/transmission are at an angle affect the turning of the crank shaft and gap measurements? Don't think so but just making sure.
It will have no effect, as you suspected.
-Andy |
Check the rocker shafts making sure that they are in the right places. Two of mine decided to slide over on me and this caused two to break and now I need to replace the cam towers.
| All times are GMT -8. The time now is 07:48 PM. |
