Hella Double Relay Fog Light Question
Hi, the PO installed Hella foglights in the car. As I was taking them out I noticed a wire that was not fixed to anything. It is "30" in the pics below. Anythoughts as to what this should fix to? Based on my research it may be the battery. Thanks.
Yes, terminal 30 would be from the battery. The schematic on the side of the relay shows the power source for the lights to be from 30, the switch for the relay activation to be 86 or 85 (2X)--one set (85 or 86) being ground, and the feed to the lights to be 87 (2X).
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
