74 Fuel Line Fitting
Hey Folks,
Anyone know the fittings that are used on the hard plastic fuel line. There is a 3/8(fuel line) and 5/16 (return line) that come from the tunnel to the tank and filter the same at the rear. Should I use a barb to attach the plastic line to the new rubber lines. Any suggestion if there are fittings that can be purchased just for these plastic line. Just concerned about if I use a barb the pressure may be different.
Any help would be appreciated.
Miki
Old 06-07-2010, 05:18 AM
cfries's Avatar
Subscribing
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 06-07-2010, 05:26 AM
BoxsterGT's Avatar
Porsche Crest
What specifically do you need?
Unless it has been changed from original, you do not have 3/8 & 5/16 hose.
It is Metric throughout. I make up Metric hose assys for most Porsche fuel & oil systems as below.............
Most often the fittings are M14x1.5 or M16x1.5 thread.
If I can help, please email me only, no PM's.
Cheers,
Len at Autosportengineering dot com
Old 06-07-2010, 09:40 AM
