grahamkissack's Avatar
Late model VDO clock repair - ideas?
So I bought a clock that works for 5 minutes then slows down and stops. I've pulled it apart according to other threads on this site. Looks like the little drive motor gets jumpy then slows down reverses a bit then runs at a lower rpm all the while going forward then backward. I don't see any bad looking solders. Any ideas? ANy idea how to separate the electronics from the gears?
"Penelope" 1980 SC Targa in Grand Prix White
Old 06-17-2010, 09:32 AM
IF it stops it tells the right time 2X a day!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-17-2010, 09:55 AM
Adrenaline Junkie
Hayabusa's Avatar
Might be time to consider a boost gauge!
No turbo in back,,, that can be changed too!
It's all a chain reaction.
Old 06-17-2010, 10:02 AM
The voltage across one of the caps is 12v while the other is 1.5v. Other threads suggest they should be the same?
Old 06-17-2010, 10:19 AM
Replacing the caps solved my clock not running in my targa (the thing's amazingly accurate, too). New caps are cheap, so it might be well worth a try. You shouldn't have to disassemble the clock further to change out the caps (presuming you've got a modicum of electronic soldering skills). Note that there's polarity when replacing the capacitors as well.
Still have to sort my cabriolet's non-running clock.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 06-17-2010, 10:39 AM
gptom's Avatar
If you have a small soldering iron, try reflowing all of the solder joints. They may have become high resistance from heating & cooling over the years. This corrects many intermittent problems.
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 06-17-2010, 11:37 AM
OK...totally screwed that up. I was removing the solder on the capacitor, dropped the unit and the delicate motor widing broke off $%&$*$!!
So now I either need new internals or another clock. I'm going to Walmart to buy a cheap quartz movement to put in the VDO housing if it will fit.
Old 06-17-2010, 11:54 AM
