shh-the robot is sleeping
Free play in short shift kit with pics
What am I missing? Coupler is tight and bushings look good to me...
Help is much appreciated!! ![]() ![]() ![]() ![]()
'88 911 Coupe, 69k miles |
In your last picture...the small set screwr on the left of the cup. Is it tight?
Matt. 83 911SC 85.5 944 NA - Sold |
Ruby911
is the play fore/aft, left/right, or all?
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Play is in all directions
Not sure I understand your question -"Play in all directions"
These may be obvious, but for example: - The lower portion of the shift lever has separated from the upper portion (not shown). - Springs for 5th/Rev are removed from housing (without them, the lever will have add'l play) - You have a late shift housing with a threaded shift box pivot pin (and lock nut). threading the pin inward/outward adjusts the side-to-side play. ![]() Am I hot or cold? Sherwood |
make sure your coupling to the trans is play free too.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
pelican sells coupler bushings with round holes, rather than with oval holes like factory. you'll like them.
... Anyway, you know what I mean... The play is left to right. However I can not determine what pin you are refering to and how to adjust it. Would you please expand? -Dan
do you know the condition of your rear coupler? I had my trans rebuilt and we put in a Wevo internal shift gate. We could hardly get into 3rd gear until I redid the rear coupler. Very easy to do and very inexpensive.
Are you sure it is OK?
I had a lot of play in my shifter. It turned out my set screw was loose on the cup. You should really check it. May save you a lot of hassel.
The "shift fork" is the rectangular, one or two-piece metal "box" that contains the shift lever and its pivot pin. On each end of the fork is a pivot pin that allows the lever to swing left-right. On early shift housings ('73-'76), these are split pins driven in from the outside of the housing. On later shift housings ('77-'86), the front pivot pin is threaded with a lock nut. From your photos, it appears you might have a later shift housing. Is that correct? If so, to remove excess left-right play, loosen the lock nut, then use a 10mm hex wrench to thread the pivot pin inward (or outward as necessary). Warning: The lock nut is usually very tight. It's easier to temporarily reinstall the shift housing on the tunnel to hold it in place, then use a 1/2" dr. flex handle and 22mm socket to loosen it (push down on handle on pass. side). ![]() Seine Systems > Blue Printing the 915 Shift Housing OTOH, if the fork uses split pins on both ends, the only way to adjust the play is to remove one or both split pins and insert a shim(s) (washer) until the desired clearance (feel) is achieved, then reinstall the split pin(s). BTW, it's preferable to space both ends equally to keep the fork centered in the shift housing. Hope this helps, Sherwood |
