If only BP had consulted Bosch:rolleyes:
Thank you for this information. Do the standard Porsche MFI injectors really have capacity to feed a MFI 935 motor? I don't need that much capacity, but am considering converting a ex-GTU 911 race car from carbs to MFI. To leave a little buffer, I'd like to have injectors capable of feeding 400 hp. Will stock injectors safely allow for that? Scott |
I offer this information regarding turbo MFI applications:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/535136-smaller-stem-valves-46-40-heads.html Read the posts by aws on his past MFI turbo project. |
Porsche 934.5 Racecar - a set on Flickr
http://forums.pelicanparts.com/uploa...1276197910.jpg http://forums.pelicanparts.com/uploa...1276198062.jpg Make sure you get a turbo boost pressure compensator. |
Steve Weiner reports a 3.0RSR "24 hour motor" delivering over 400hp - you might want to give him a call. |
Before considering an MFI turbo, consider the following nuggets of experience which dissuaded me:
Don't worry guys - I'm not doing an MFI turbo! I don't need that frustration!
I was just wondering if stock MFI injectors would handle 400 hp so I can safely use them on a 350+hp race engine, with a bit of buffer to be safe. Sounds like that's a go ... Scott |
| All times are GMT -8. The time now is 08:14 PM. |
