-   -   Found source: lug nuts for BBS E52 wheels (http://forums.pelicanparts.com/porsche-911-technical-forum/547066-found-source-lug-nuts-bbs-e52-wheels.html)
strawman 06-08-2010 08:18 PM
I bought a set of 16x7 & 16x9 BBS rims for a song on Craigslist, only to find out later that BBS no longer sells the shouldered lug nuts. Here is a picture of one of these wheel centers:
http://forums.pelicanparts.com/uploa...1276052886.jpg
I searched this forum for solutions, and was disappointed by the suggested solutions -- find some used lug nuts, machine the lugs bores to accept acorn-style shoulders, and even fogettaboutit look for other wheels. :mad:
So I mic'd the lug bores, and found the following:
Lug Nut Shank Length: 1.095" maximum (depth from inner shoulder to where the wheel meets the hub)
Lug Nut Shank Diameter: 0.75"
Washer Outside Diameter: 1.25" maximum
Using that info, I searched the internet for open end steel lugs and found that Custom Wheel Accessories (714-827-5200) carries them -- part number 5108OP. Since I'm using 100mm length 14mmx1.50 lugs on my Subaru WRX-powered 914 and wanted open-ended nuts, these seemed like the ideal solution. I called ACW on Friday and ordered two full sets (40 lug nuts) and matching chromed washers (part number 6002). With shipping and handling charges, the total was $62.58.
They arrived today, and they appear to fit perfectly. ACW also manufactures closed-end nuts, part #5108.
Here is a pic of the nuts-n-washers:
http://forums.pelicanparts.com/uploa...1276053090.jpg
YMMV, Geoff
rsrfan 06-09-2010 09:26 AM
Very cool. Thank you for your persistence...
mskala 06-10-2010 10:19 AM
Wow, that's great info. I have the same wheel type, but have only been able
to find lugs from Jegs, and they needed to be cut as they have too long a shank.
dgale914 08-16-2010 11:28 AM
You're the man! I just ordered 3 sets for my wheels. I have 1 set of 8.5" x 16" wheels, and another in 10"x17". Had no lug nuts for either set and was considering re-machining the wheels, etc.
Good find!
Doug Gale
TrackMasters Racing
