83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest Dead Horn @ Dead Center
When I got the car (83 SC), it had a Dino wheel and horn button (I since put a Porsche one).
It does not work at dead center but does as soon as I go left or right.
Also, probably related if there was a screw-up when the change the steering wheel, the flasher lever does not return after doing a left or right turn.
I'm thinking somewhere down the stack?
J.J.
Who Will Live... Will See
Old 06-09-2010, 12:11 PM
m1franck's Avatar
I found the ground connection on these horn button to be unreliable at best. Try a test by removing the entire horn button, connect a wire to the outer portion of the ring that see's continuity when the horn button is depressed. Run this wire to a good know ground source & try it out.
I fixed this problem on my car by connecting an additional wire to the button & grounded it to the wheel adapter. Horn works great now.
Old 06-09-2010, 12:38 PM
JJ 911SC's Avatar
I'll try that...
J.J.
Old 06-10-2010, 12:51 PM
