Removing shift knob and leather shift boot?
I want to repair/replace the leather shift boot on my '85 Targa, but how does one take off the shift knob. A quick look in my Bentley's shows removal of an '87-89 knob by prying out the middle of the knob.
My '85 has a stock? black shift knob that doesn't look like it has a removable center piece. Also, does anyone know - do I need to remove the entire center console, or will the leather ship boot simply lift off once the shift knob is removed. TIA & happy holidays! |
The way I have heard of removing the factory knob is to use an open end wrench pressed to the bottom of the knob, and whack with a hammer. Sometimes this will destroy the knob though. If you are lucky and don't destroy your factory knob, you will need a new crush washer.
Don't whack too hard - tap,tap,tap and it should slide off. I was able to reuse the crush washer...
Uuuuugh. 915 transaxles are so neanderthal! Crush washer? How barbaric.
Now, where's my champagne and caviar? |
| All times are GMT -8. The time now is 07:21 AM. |
