-   -   Chain Tensioner Question... (http://forums.pelicanparts.com/porsche-911-technical-forum/547222-chain-tensioner-question.html)
Glen Pettigrew 06-09-2010 05:47 PM
1974 911S 2.7 (completely stock, or so I thought)
What kind of tensioners are these?
Removed Chain box covers to replace seals and install pressure fed
tensioners and this is what was installed for tensioners on both sides:
http://forums.pelicanparts.com/uploa...1276130639.jpg
http://forums.pelicanparts.com/uploa...1276130682.jpg
These appear to be purely mechanical tensioners and are adjusted with
an allen wrench. No springs at all.
Thanks...
yelcab1 06-09-2010 06:08 PM
Fully mechanical tensioner, used for racing engine a lot.
silverc4s 06-09-2010 06:53 PM
Solid, mechanical tensioners are generally not a good idea on a street car. In order to work properly, they will need adjustment at regular intervals, as the chains wear & stretch.
Carrera tensioners are the best solution for most of us.
Glen Pettigrew 06-09-2010 07:35 PM
yelcab1,
Thanks much for the quick answer!
Bill,
Thank-you for your answer & advice.
Can't imagine why these were put on the car. The owner of
the car that this motor came from never raced it.
Anyway, as seen in the photos, I have already removed them
and am putting on the pressure fed tensioners. I guess I
can keep them as a tool when working on tensioners and/or
cam timing etc.
Thanks again to both of you..
Glen Pettigrew
DanielDudley 06-10-2010 03:27 PM
People use them because the can not fail, and they are fairly inexpensive. I found a set on my 78 SC as well. Carrera tensioners now.
DanielDudley 06-10-2010 03:32 PM
BTW, I am not advocating them in any way. The biggest downside IMO is that they cannot compensate for engine expansion during warm up and cool down. I would expect that if they were too tight they would cause rapid chain wear or stretch, which is similar. Set up properly, I would expect them to be slightly sloppy when dead cold.
But I am not a doctor.
