Toe Angle vs. Tie Rod Turns
Does anyone know how much one turn of the tie rod adjuster changes the front toe angle for turbo tie rods?
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
PRO Motorsports
IIRC, one full turn of one side changes toe setting by 4mm.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
I will just add the obvious for future reference, turn both sides equal amount to keep your steering wheel centered. Or fix a non-centered steering wheel by turning each side different amounts while concurrently fixing the toe. Or if the toe is good but the steering wheel is off centered, turn each side the same amount in opposite directions (one side in, other side out).
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
