grahamkissack's Avatar
Cheap immobilizer ideas (hidden switches etc)?
I'm getting tired of removing the fuel pump relay or distributor rotor. Anyone ever come up with a cheap immobilizer like a hidden switch that kills the fuel pump relay or using an existing switch to control the relay?
Thanks, Graham
"Penelope" 1980 SC Targa in Grand Prix White
Old 07-27-2004, 10:51 PM
klaucke's Avatar
Yeap: http://www.pelicanparts.com/techarticles/Mult_ignition_cutoff/Mult_ignition_cutoff.htm
Old 07-27-2004, 10:52 PM
Run a remote switch to the DME box ground wire. If that is left open, nothing in the car works. We used this for my brothers club race car kill switch.
Old 07-27-2004, 11:12 PM
Just use any switch which can not be seen but easily reached from the drivers seat.
I would not disconnect the ground wire from the DME (although the previous post had good results). When the ground is disconnected and power is turned on, current can be sourced through all sensor inputs and outputs to ground, which are NOT designed to source power. It is much safer to cut power.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 07-28-2004, 04:40 AM
JNadal's Avatar
Drive the car untill you're out of gas
Old 07-28-2004, 04:51 AM
A time delayed kill sw is good theft prevention. You want the car to die as the car is being driven away. This should be part of a multi layered system.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-28-2004, 05:01 AM
Doug Steinel's Avatar
Guys, the car has CIS and CDI not DME. What would be an effective yet safe way to rig up a kill switch for a stock SC... a kill switch which won't screw up the electronics?
77 911, 3.0L
Old 07-28-2004, 08:32 AM
The routine fuel pump ground on/off sw is well known by every crook. Do the well known routines then confuse them when they believe ther're delivering your car to the chop shop.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-28-2004, 09:34 AM
klaucke's Avatar
Ground out the tachometer and hence the coil won't fire... see my first post
Old 07-29-2004, 06:29 PM
charlesbahn's Avatar
The club?
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 07-29-2004, 06:50 PM
pwd72s's Avatar
Carjacking is a problem on Vancouver Island? I mean, all escapes to the N. American continent easily cut off? D-OH! Then the Canadian cops aren't doing their jobs well, are they? Don't feel bad...they aren't doing so hot down here as well...
Old 07-29-2004, 07:02 PM
Yellowbird RS's Avatar
Clifford virtual key
http://www.clifford.com/guides/ogs/virtualkey_owners.pdf
X/A
Old 07-29-2004, 07:31 PM
I have a $40 heavy-duty Bosch racing-type cutoff switch--twist the handle 90 degrees and it comes out and cuts off the ground--and it's under the trunk carpeting. (My battery happens to be relocated to the smuggler's box, which makes that location easy, but you could put it anywhere.) I don't even bother to take the handle--the key, in effect--with me, I just twist it out and leave it under the carpet. Between finding the handle, reinstallng it and then firing up a car with chokeless PMO carburetors, I figger I'm safe from an thief under the age of 60.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-29-2004, 09:04 PM
Hilbilly Deluxe
emcon5's Avatar
That will work on a car with points. His SC doesn't have points, it has a magnetic trigger, and the Tach signal doesn't come from the coil, it comes from the CDI.
82 911SC Coupe
GTI Cup #43
Old 07-29-2004, 09:58 PM
Hi Steve.. what's to stop a jump across the terminals.. or maybe the idea of a hidden sw is the idea ? and I use a layered approach figuring he'll jump the ignition with his own parts and harness and be able to jump the starter. I was told to delay him as long as possible thus making more tense and then kill the car if he's driving away.. I even have one of those pagers in case I feel like getting shot.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-29-2004, 10:02 PM
fred cook's Avatar
Cool Go for the obvious.....
Any experienced car thief will probably find a hidden switch no matter where you put it. Why not do something different, such as turn your driving light switch into a kill switch. Or turn the ashtray into a switch so that the ignition or fuel pump is off when the ashtray is open. Or maybe even put a contact switch under the seat so that all you have to do is move the seat all the way back or forward to trigger the imobilizer. The idea here is to be creative and not obvious.
Good Luck!
Fred Cook
'80 911SC coupe
Old 07-30-2004, 08:31 PM
Re: Go for the obvious.....
yeah Fred.. see what the pro installers do then somewhat fake that install yourself to fake him out and then have a layered attack against the crook.. my next bright idea is to somehow rig up an ear damage electonic siren. The Galls brochure has plenty of them for sale. Something that'll trigger pain if your within 10ft of the cabin.. that'll be "creative and not obvious" wouldn't you think?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-30-2004, 09:36 PM
bit bit is offline
bit's Avatar
Hi Guys,
It may be a bit overkill, but usually I pull the ign coil wire and take it with me (knowing I have a spare back home) plus I use a club. I think that this is about as imobile as it can practically be. I never really like to pull my FP relay (cuz in my car, the FP does nothing as it was bypassed by some fool PO in its' past life). Switches can almost all be found given the time, if the crook has it. Beyond this if they really want your ride that bad it is gone anyway by whatever means. My thots anyway...
Damn crooks! Most immobile cars are found vandalised!
But you still may have your undriven (by a crook) car.
.Steven
1980 SC
Old 07-30-2004, 09:40 PM
Stephan
Old 07-30-2004, 10:37 PM
MAS MAS is offline
I already have a cheap imbobilizer... the stock 915 gearbox
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 07-31-2004, 07:40 AM
