Carrera emblem reinstall
Hello. I tried doing a search but couldn't find anything. I am looking to reinstall the Carrera emblem on my decklid. I was thinking about using epoxy. Is this the way to go or should I try something else.
Thanks,
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 06-12-2010, 12:56 PM
Hi Chris,
I certainly wouldn't use epoxy. It would be permanent and also is very difficult to remove if you've gotten some of it where you don't want it. I'd try a 3M general adhesive. Or if you feel froggy try cutting 2way tape to the script.
Good luck!
O2 In Sully We Believe
Old 06-12-2010, 01:14 PM
kodioneill's Avatar
Thanks,
Chris
The new emblem has two sided tape on it.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-12-2010, 01:18 PM
kodioneill's Avatar
Here's a thread that shows the location.
1987 carrera emblem location
1982 chiffon 911sc
Old 06-12-2010, 01:20 PM
benp911's Avatar
+1 double sided tape
Old 06-12-2010, 01:36 PM
Harbor freight has great 2 sided tape.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-12-2010, 01:51 PM
Use the real stuff...
3M Automotive Attachment tape
It's thin and works great.
I have some left over from my Mustang build
PM me and I can get some to you.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 06-12-2010, 03:29 PM
Thanks for all the input. I will give the double sided tape a shot. Tomphot, I will send a pm your way.
Thanks,
Chris
Chris
95 993 C2
Old 06-12-2010, 06:34 PM
Checked out
McLovin's Avatar
Obviously epoxy is a horrible idea, but you're not doing that so ok.
Double sided tape is good, that's the factory way.
But on mine, I epoxied thin magnetic strip material (cut to fit in the grooves) to the back of the emblem. On the back of the emblem, if you remove the factory double sided tape, you are left with a groove that thin mag strips fit in perfectly. Nothing special, just stuff you can get at any local hardware store.
That way, when I wax I can take it off completely. Or, sometimes I run without the emblem at all for a "cleaner" look.
Old 06-12-2010, 08:43 PM
I picked up some 3M emblem and plastic adhesive from Advanced Auto. Worked fine.
Mike
Old 06-13-2010, 07:20 AM
