Hello,
I am having some problems with my brakes and I am rebuilding all 4 so I naturally decided to have the rotors turned while I am at it. But I had just a few questions by the way I have a 66 911 with a 2.7 and stock brakes/suspension or so I thought!! My front rotors are the slotted type with 1 being 18mm and the other 19mm, After a bit of research I have learned that the slotted rotors appeared first on the 67 "S" so I know they are not origianl. My questions are: 1. How can you apply larger rotors without larger calipers? The steel "M" calipers were made for a thinner rotor so I would think the pad would scrape without the brake pedal being applied!! 2. My rotors are too worn to be turned or so I am told so which rotors should I get?? Stock or the vented or something else?? 3. My rear rotors are 9mm solid and one has a notch missing so I am going to have to replace, so how big of a rotor can I fit on the rears with the "M" caliper?? I have a Carrera 3.2 rear rotors and was wondering whether they are usable?? I wold really appreciate some inout because I know that slotted or drilled rotors decipate heat better and are therefore more effective in performance circumstances but what I need to know is can I use them and If so how think ??20mm??24mm?? Thanks For All Input, Ron Dailey
1969 Porsche 911 S - Only one and its For Sale
