-   -   running lights 86 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/548019-running-lights-86-911-a.html)
Seneca 06-14-2010 03:39 PM
Right side running lights wont work.. All the other lights work just the right side runners thanks for the help,
Bob:
86 911 Targa 06-14-2010 04:10 PM
Bob:
Check this diode.
It's located adjacent to the light switch
on a very small PC board.
Note: This diode was only used on the '86 3.2 cars.
Starting in '87, an updated light switch was introduced,
(-03), with one additional contact.
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1276560583.jpg
kbruz 06-14-2010 07:50 PM
On the 86, there is a diode in the circuit. It is usually under the knee rest just below the ignition key, or jut to the left of it. It's in a white/clear square case, similar to a fuse holder.
DRACO A5OG 06-14-2010 10:19 PM
Make sure the bulb's contact is not corroded, mine was and after cleaning it worked fine.
I discovered this because I thought bulb was out but when I started to remove it with the running lights on, it came on when I put it back it went out. I proceeded to clean it, Voila no more issue.
Rot 911 06-15-2010 04:13 AM
Correct. Everything old is new again. I asked this same question and got the same answer all the way back in 2001! http://forums.pelicanparts.com/porsche-911-technical-forum/54353-exorcist-needed-parking-light-diode.html
