Late model VDO clock repair - ideas?
So I bought a clock that works for 5 minutes then slows down and stops. I've pulled it apart according to other threads on this site. Looks like the little drive motor gets jumpy then slows down reverses a bit then runs at a lower rpm all the while going forward then backward. I don't see any bad looking solders. Any ideas? ANy idea how to separate the electronics from the gears?
"Penelope" 1980 SC Targa in Grand Prix White |
IF it stops it tells the right time 2X a day!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Adrenaline Junkie
Might be time to consider a boost gauge!
No turbo in back,,, that can be changed too! It's all a chain reaction.
The voltage across one of the caps is 12v while the other is 1.5v. Other threads suggest they should be the same?
Still have to sort my cabriolet's non-running clock. Brian
'82 SC Targa '83 SC Cabriolet |
If you have a small soldering iron, try reflowing all of the solder joints. They may have become high resistance from heating & cooling over the years. This corrects many intermittent problems.
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
OK...totally screwed that up. I was removing the solder on the capacitor, dropped the unit and the delicate motor widing broke off $%&$*$!!
So now I either need new internals or another clock. I'm going to Walmart to buy a cheap quartz movement to put in the VDO housing if it will fit.
