oly oly is offline
1985 Carrera Coupe
Question OE Boge rebuild and revalve?
Does anybody know why the rebuild and revalve options do not seem to be available for Boge shocks? If it can be done for Bilsteins why not for Boges?
Art
Old 02-05-2009, 02:59 AM
Friend of Warren
Because Boge doesn't choose to do so.
Kurt V
Old 02-05-2009, 06:36 AM
oly oly is offline
1985 Carrera Coupe
Rats! The scurvey Boge dogs!
Art
Old 02-05-2009, 10:01 AM
oly oly is offline
1985 Carrera Coupe
Isn't their anybody out there that wants to make a bunch of money doing this?
Art
Old 02-05-2009, 06:01 PM
Certified Pre-Owned
BGCarrera32's Avatar
I presume this is for your '85?
You put Bilstein inserts in the BOGE housings for the front struts. Bilstein can valve those any way you want. You replace the rear dampers (shocks) with Bilstein and Bilstein can valve those any way you want. The BOGEs in back are likely shot anyway.
An expert around here on taking care of valving is Steve Weiner at Rennsport Systems...dealing with Bilstein directly isn't always the best, but running through Steve or the like is.
'84 Carrera Coupe
Old 02-05-2009, 06:15 PM
oly oly is offline
1985 Carrera Coupe
Yeah, I'll probably end up going the Bilstein conversion route. I was hoping to save some $ and reuse my Boge Sports though.
Art
Old 02-05-2009, 06:40 PM
juicersr's Avatar
Know this is an old thread, but just to verify, Bilstein struts are thus a direct fit into Boge housings, just right-side up instead of upside down like in the Bilstein housings?
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 06-16-2010, 07:26 PM
No Bilstein makes an insert that will fit in a Boge housing. It is not the same as the insert they make for their own housing.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-16-2010, 07:39 PM
juicersr's Avatar
Aha, i knew it couldnt be that easy. I have a set of Bilstein struts lying around that i was going to revalve and put in the Boge struts on my Carrera... guess not.
dzugautomobili.com
Old 06-16-2010, 08:03 PM
If you have the complete strut not just the cartridge they interchange across all years .
1995 993 coupe
2012 Boss 302
Old 06-16-2010, 08:16 PM
